Electrical have headlights/markerlights shut off when car is turned off?
I really wish I could set my headlight stalk to ON and that the power would be cut to the headlight/markerlights/any exterior lights when I remove the key.
As it stands, if I leave me lights on and lock the car the headlights go out but the car marker lights stay on.... I don't like this
any ideas?
2003 MCS
any ideas?
2003 MCS
Turn off your lights?
There might be direct wiring, but you may have to go through the BCM - BCM would be much harder. If direct, you'd have to run a relay triggered by an ignition powered source, draw power and cut the original wiring.
Now that I think about it's probably BCM as you can turn on the signals on either side with the turn signal even when the car is parked (safety feature for parking on narrow roads.)
2003 MINI did not have this option in the US. From my understanding if you want them you'll have to get the 2005 version of the stalk, and the dealer will have to program the auto headlight feature into the computer.
09R56
Nov 16, 2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
