Noisy Tires
Noisy Tires
Hello all
Am presently a MINI wannabee
Have test drove 2 09 Clubbies and both had what I think is excessive
tire noise.
Both cars had around 45K on the clock and run flat tires.
Is that a characteristic of the run flats??
Also for all the money I am about to spend I do not even get a spare
and the tools to change a flat
Am told this is normal with run flat tires
Comments please???
Thanx
tire noise.
Comments please???
Thanx
Yes normal
Wife's has Bridgestones and sounds like a school bus
Mine has Dunlops and not too bad at all, both runflats
You don't need a spare with runflats....as the name says you can run with a flat.
ContiProContact run flat tires seem to be the quietest of the bunch if you need to stick with RF. Dunlops were once the worst of the bunch, but I when they all reach about half life, Pirelli's included, they all start to sing a bit more on the highway.
Hello all
tire noise.
Comments please???
Thanx
tire noise.
Comments please???
Thanx
They are also:
- over-priced (+100/each vs. proper tires)
- ride excessively harshly due to needlessly stiff sidewalls beyond what would is needed for good handling or ride quality
- not available at all in the top of the line tire models (either summer or winter)
- are only good for 50 miles after puncture, then are toast (good luck if you outside of the 50 mile radius from home - you will get stranded)
- usually can't be patched after puncture
Basically, RFTs suck.
Get a proper tire!
alex
I had Conti runflats on my 2012. They were incredibly noisy, handled horribly and rode like they were made of concrete. Plus, they barely lasted 15k miles. I replaced them with Michelin Pilot Super Sports in 215/45/17 and it instantly solved all of those issues. The road noise and handling are superb in comparison. My only regret is not making the change sooner!
To the OP, even if the S model has no spare, they do include the jack and related tools, they are underneath the removable floor in the boot.
J
J
J
J
YMMV,
alex f
P.S.: To add a piece of mind to go with ditching RFTs, I bought the Conti ComfortKit from TireRack: http://www.tirerack.com/accessories/...Tire+Inflation
