R56 Correct spark plugs for a 2009 R56 Base Hatchback??
Hello all, I have been trying in vain to accurately obtain a part # for the correct spark plugs for my 2009 Mini Cooper Base hatchback. The car was produced BEFORE the 2009 split. I have conflicting information concerning BERU and NGK part #s. One website contradicts the other and even NGK can't seem to tell me what's what. Can someone please inform me as to the absolute correct spark plugs? I am not interested in anything but OE or direct replacement for the OE. Thanks so much!!!
Depends on your build date found in your driver door.
Use the following part number if built before 9/09:
BERU 12ZR6SP03
12120035933
From 9/2009 on
BERU 12ZR6SP02
1212215816
Go here to confirm part numbers by entering part of your VIN.
http://realoem.com/bmw/select.do?kin...one=USA&arch=0
BERU 12ZR6SP03
12120035933
From 9/2009 on
BERU 12ZR6SP02
1212215816
FYI That part number is for the turbo model, not the N.A. Cooper
Yep, good note on the split year:
http://www.ecstuning.com/Mini-2009-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Maintenance/Engine/Ignition/
You can see the manufacture types in red and well as the split years.
09R56
Nov 16, 2022 10:49 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
marendt428
Nov 14, 2015 10:03 AM
