Drivetrain steam coming from enigne area
Old Mar 27, 2013 | 06:59 PM
minime331's Avatar
minime331
so i've notice while its raining, cold out and i stop at a light or park the car there is some steam coming out of the top grill on the driver side. one day i decided to look under the bonnet and noticed the steam was coming from the sponge on top the radiator under the air intake. is this normal? it doesn't smell or anything. is there something i can do to stop this?
thanks
Old Mar 27, 2013 | 07:29 PM
Braminator's Avatar
Braminator
Check your coolant level first. You might have a leak at your thermostat housing.
Old Mar 27, 2013 | 07:31 PM
Eric_Rowland's Avatar
Eric_Rowland
Yes and no. It's normal, and not much you can do. The intercooler gets hot, and the rain comes in the same way the air does. Just think of it as a smoking dragon.
Old Mar 27, 2013 | 07:39 PM
Braminator's Avatar
Braminator
I forgot about the rain.
Old Mar 27, 2013 | 07:55 PM
minime331's Avatar
minime331
so dont worry about it
Old Mar 28, 2013 | 05:45 PM
Da_Ghost's Avatar
Da_Ghost
Indeed. Same thing happens after taking the car to a manual car wash. Stopped at a light with steam coming out of the scoop, guy next to me looked at it, then looked at me kinda worried :p If there's no leak, then everything is fine.
Old Mar 28, 2013 | 05:58 PM
On heavy rainy days the little foam strip above the radiator gets soaked and then when you stop at a light the radiator heat steams the moisture out of the foam. It happens all the time.
http://www.ecstuning.com/Search/17107515479/ES37539/
Here is the foam.
Old Mar 28, 2013 | 08:46 PM
minime331's Avatar
minime331
Here is the foam.
thats it
Old Mar 29, 2013 | 02:51 AM
JAB 67's Avatar
JAB 67
Don't completely assume that there isn't a slight leak in the radiator. Check the plastic underbody pan beneath the radiator for evidence of a coolant leak. Mine has a very small pin-hole leak somewhere near the top of the radiator, passenger side, that does what you describe, but there is clear evidence of leaking coolant on the underbody pan.
Getrieben
Sep 12, 2024 07:03 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
theateist
Aug 22, 2015 06:58 AM
StuRat
Aug 20, 2015 07:17 AM
damncajun
Aug 17, 2015 08:25 PM
