Noisy brakes
Old Mar 13, 2013 | 09:43 AM
wodturner's Avatar
wodturner
Noisy brakes
I got my first mini about 2 months ago. An 06. I now find the brakes are making a squeaking noise when I stop. I take to the shop for the warranty work. They call me saying the front brakes and rotors need replacing to get rid of the noise. The brakes and rotors have plenty of 'meat' on them but the brakes are just noisy. It is not a safety hazard.
I called the dealer I bought it from and he said the warranty won't cover them because they are brakes. He did say he will split the cost with me.
Am I having smoke blow up my ... ?
Bob
Old Mar 13, 2013 | 10:24 AM
martinb's Avatar
martinb
Likely smoke up your butt.
If there's plenty of "meat" on the pads and the rotors aren't near the end of their life (near the minimum thickness), then you may be able to solve the problem by cleaning the rotors installing new brake pads, and doing a proper bedding procedure.
Remember that the bedding procedure is critical to good brake performance. A layer of the pad material must be transferred to the rotor. Read here:
http://www.stoptech.com/technical-su...and-procedures
Old Mar 13, 2013 | 10:41 AM
ZippyNH's Avatar
ZippyNH
My mini makes a bit of noise....
The cause is simple....
as pads wear, the very edge of the rotor does not get worn down, since there is no pad grinding it down, so a tiny "lip" or ridge forms....
When the pad is mostly worn, the metal backer plate can start to run on the ridge or lip...causing a squeeling noise, with pleanty of "meat" on the pads.
Old Mar 13, 2013 | 12:12 PM
ZippyNH's Avatar
ZippyNH
Simply touch your front rotor...and you will feel a lip/ridge on the edge. Some pads, Like the OEM ones are NOT very rotor friendly, and the MINI OEM rotors are kinda soft...
Sep 10, 2015 10:52 AM
tylewis
Sep 6, 2015 01:07 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
