R50/53 Will these wheels fit my r53
Old Feb 20, 2013 | 01:39 PM
R53minime's Avatar
R53minime
Does anyone know if esm 17x8.5 wheels will fit my 04 Mini Cooper s stock suspension I really want to get these wheels but not sure if they will fit or not
Old Feb 20, 2013 | 01:58 PM
R53minime's Avatar
R53minime
I apologize for so many posts my phone kept saying it didn't work
Old Feb 20, 2013 | 02:55 PM
quikmni's Avatar
quikmni
What is the offset of the wheels?
What size tires do you plan to install?
Old Feb 20, 2013 | 03:30 PM
R53minime's Avatar
R53minime
They are et20 and I just bought 215/40/17 like a week ago would they fit if I just had those put on
Old Feb 20, 2013 | 04:13 PM
quikmni's Avatar
quikmni
The 215/40-17 tires will work on a 8.5" wheel.
The et20 should be OK on the inside (towards the strut) but I am not sure about rubbing on the outside because I suspect the wheel/tire will be sticking out past the wheel arch on the rear.
Hopefully, someone with more insight on this wheel size will respond.
Old Feb 20, 2013 | 08:53 PM
minsanity's Avatar
minsanity
That calls for stretch & camber, unless you're planning to lift it.
Old Feb 20, 2013 | 09:08 PM
ForcedFed4's Avatar
ForcedFed4
+1 on the Camber/Stretch, probably need a 205 and about -2 degrees to get them inside, could also trim up fender trim. depends how low you are really.
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
O4mcs
Aug 6, 2015 05:42 AM
