Projector Headlight Help!
Old Feb 11, 2013 | 10:23 PM
clamport's Avatar
clamport
Hello, I have a 2004 R50 with the OEM Xenon package, but the lenses are getting really really yellow and faded. I hate the way that they look right now, I've tried restoring them multiple times but I got no results. It's also very hard to see at night with my lenses all icky. Now here's my question, would the Spec-D projector headlights work on a xenon equipped car? What if I transfer the ballasts over (or buy a new HID kit)? I love the look of the projectors, but I don't want to spend $1000 on a pair of new xenons. So I would like to go with the eBay projectors. Please help me out here
Cheers!
-Cristian
Old Feb 12, 2013 | 12:07 AM
BlwnAway's Avatar
BlwnAway
Don't know about the aftermarket, because I'm not familiar with there setup, but one thing you might consider is taking them apart, like you do with a joey mod, and trying to polish the inside of the lense also. If you're thinking of reolacing them anyway, why not give it a shot, all it will cost is the price of a heat gun, if you don't already have one.
Old Feb 12, 2013 | 12:08 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Try to buy lenses. I believe they are a separate part.
Old Feb 12, 2013 | 03:45 AM
ACallahan's Avatar
ACallahan
From what I hear, you get what you pay for with the Ebay lights. I just kinda kept a lookout for used OEM and went that route.
Old Feb 12, 2013 | 04:10 AM
yetti96's Avatar
yetti96
They are not unfortunately.
This is true, plus with the OEM setup it might require some rewiring or otherwise it might not be plug-n-play. See if you can get used facelift projectors or I think there were some pre-face lift ones like yours on the marketplace a few days ago. A few hundred bucks at best for used OEM might still be better than $300 for ebay stuff.
Old Feb 12, 2013 | 04:32 AM
BlwnAway's Avatar
BlwnAway
Correct on the lenses not being a seperate part, but that also gave me another idea, again going the Joey mod route I do believe the lenses are the same, hid or not, double check this, but if it's correct, you could buy a used set of non hid headlights much cheaper and simply change the lenses.
Taking them apart is very simple, the idea of the process is much worse than the process itself, once you've done one & see exactly how the go together, you will see how simple it really is.
Old Feb 12, 2013 | 05:13 AM
MINIFatherFigure
That sounds good to me - sorry about the separate part thread. I saw some cleaned up on another (BMW) forum. looked good for the cost / effort.
Old Feb 12, 2013 | 11:18 AM
clamport's Avatar
clamport
Thank you all for the replies, i found these projectors that actually come with HID's (i wonder if those would work)? http://www.ebay.com/itm/SLIM-HID-200...00881306624%26
And then i found these which look like OEM halogen, but they say HID on them, but hopefully i could just change the lenses out: http://www.ebay.com/itm/8000K-HID-02...5f73b9&vxp=mtr
Old Feb 12, 2013 | 11:19 AM
clamport's Avatar
clamport
Oh yeah, and these: http://www.ebay.com/itm/IPCW-02-06-M...bb0a92&vxp=mtr
Old Feb 12, 2013 | 09:58 PM
chaseabryant's Avatar
chaseabryant
The only thing that you would want to be careful about is whether or not these headlights were designed to throw high intensity light. Even though some of them have a projector housing, that doesn't mean that they were designed to be used with HID lighting. You would also be losing the auto-leveling feature that your current headlights have.
I'm going to agree with the others in saying you should purchase a set of used OEM headlights to replace your current set, or purchase a non-HID pair and swap the lenses.
-Chase
Old Feb 12, 2013 | 11:58 PM
clamport's Avatar
clamport
I understand that completely, but my othet question is if I used halogen projectors and bulbs on a xenon equipped car would it work?
Old Feb 13, 2013 | 12:30 AM
MINIFatherFigure
If you re-wire it. 12v globes don't respond well to 12kv pulses.
Old Feb 13, 2013 | 01:57 AM
BlwnAway's Avatar
BlwnAway
Correct, you'd have to find out for sure that the factory wiring to charge the ballasts & ingniters is 12v or if they have changed something in the "pre-hid" wiring for factory hid cars.
If it is, then yes it would work, you'd just have to splice in your new plug wiring pre-ballast, or wherever in the system is the last true 12v source before conversion.
Clamport, I still think your first step should be to at least try & polish the inside of the lens also, as I said earlier, it'll only cost you about $30.00 for a heat gun if you don't have one & should only take an hour or so per side for a first timer, I've had my lights apart a few times already, it's really no big deal, PM me if you want to try it & I'll walk you through it step by step.
Old Feb 13, 2013 | 02:57 AM
MINIFatherFigure
There are 2 'boxes' for each light. One is under the lamp unit - The other inside the cabin in the dash. Cannot say exactly where - The stealer when in there under warranty and I haven't been back. I just recall what I was told. Maybe you need a manual - Haynes / Bentley??
Old Feb 13, 2013 | 03:06 AM
BlwnAway's Avatar
BlwnAway
Yup, this is the reason you need to check to see if it's a regular 12v supply out to the headlight itself.
Old Feb 15, 2013 | 03:14 PM
clamport's Avatar
clamport
Hmm, does anyone know if there is a how-to on installing halogen projector headlights in a xenon equipped car?
Old Feb 15, 2013 | 03:16 PM
clamport's Avatar
clamport
I appreciate all the help by the way!
Old Feb 15, 2013 | 06:06 PM
ACallahan's Avatar
ACallahan
Why didnt you stick with OEM? I am sure you could have found some good used ones ,or did you just not like the xenons anymore?
Old Aug 5, 2014 | 02:54 PM
sameer's Avatar
sameer
just wondering if this project was ever completed. I have the same problem with my non projector HID's. My HID fogs throw more light than the headlights. I did see ipcw's somewhere that come prewired with 35W HID's
Old Aug 5, 2014 | 06:18 PM
jamez's Avatar
jamez
ECS has some nice projector looking halogen lenses available
Old Aug 8, 2014 | 11:29 AM
Thanks Jamez : Yes we do , they are both here :
Chrome:
http://www.ecstuning.com/News/R50_R53_R52_Mini_Cooper_S_JCW_Convertible_Helix_Ch rome_Projector_Headlights_Halogen_2002_2003_2004_2 005_2006_2007_2008/
Blackout Headlights
http://www.ecstuning.com//News/MINI_Gen1_Cooper_S_JCW_Convertible_Halogen_Ellisoi d_Projector_Blackout_Headlights_2002_2003_2004_200 5_2006_2007_2008/
More blackout versions
http://www.ecstuning.com/News/R50_R52_R53_MINI_Cooper_Helix_Blackout_Projector_H eadlights_Black_Chrome_Ring_2002_2003_2004_2005_20 06_2007_2008/
Old Aug 10, 2014 | 05:57 PM
AlexQS's Avatar
AlexQS
If it were me, I would buy halogen headlights, take the lenses off with Joeymod, then put the new lenses on your old oem hids.
Regarding eBay projectors, they are designed for halogen bulbs, and are not intended for HID bulbs -even though hid bulbs are available, the light output is not good, and they cause a lot of glare for oncoming drivers.
The light source in an hid bulb is an electric arc going through hot xenon gasses in the glass tube (light bulb) The light source in a halogen bulb is the wire element. The wire element or the illuminated gasses are NOT in the same place relative to the base of the lightbulb, therefor the reflector bowl in a true hid projector is shaped a little differently than a halogen projector.
Old Aug 13, 2014 | 07:33 AM
Harkness's Avatar
Harkness
Question about Lighting
I hope this is the right thread to post in. I read the earlier questions about having OEM Xenon lights. My question is this my stock lights are not Xenon or HID what is involved if i want to upgrade my lights to projector headlights? I found a set on amazon,
Amazon.com: Mini Cooper Base/S Black Halo Projector Headlights: Automotive Amazon.com: Mini Cooper Base/S Black Halo Projector Headlights: Automotive
that's the link, my current setup has the high beams mounted on the front grill, while it's cute i'd rather change it over.
thanks,
-Harkness
Old Aug 13, 2014 | 07:38 AM
Harkness's Avatar
Harkness
Another question
Sorry I just remembered, I'd like to put in fog/driving lights in the open spots in the lower front fender, is there a kit for this? I've found the one that mount to the grill, that's not what i'm after.
Old Aug 13, 2014 | 08:19 AM
If you want the direct fit and very close to OEM look and feel of the newer projector style, we have them above and below for the Gen 1 MINIs. You have to watch those EBay and amazon ones as the fitment guides most of the time are way off. And its a hit or miss chance.
We have added a third style now.
H7 bulbs are also linked on each item landing page.
