Suspension Rear Sway Bar Size
Rear Sway Bar Size
Does anyone know the thickness of the rear sway on the 2013 Cooper S with the factory sport suspension? I'm trying to get as much up to speed as I can on mine before it gets here sometime in March.
Thanks!!
Thanks!!
It could be either as I've seen both on standard R56's.
Either way I recommend stepping up to an Hsport Comp Sway bar.
I am thinking that the rear sway upgrade to the sport suspension could be the only handling mod needed to really have fun with this as a daily driver (tire too, of course)
Sport suspension seems very tight and compliant, but it is also brand new lol. Def. more under-steer with the R56 and the rear sway bar will quell that to the best of its abilities.
I measured the rear and got 18mm, but I noticed on the spec sheet that it doesn't list sport suspension. Just the sport package. This is a 2012 btw. I've put 19k on the car and I think I am
just now finding out the car has sport suspension haha.
18mm rear sway bar correct?
Handling is perfectly neutral and it totally changed the handling of my car. Great on the road or on the track. I highly recommend this sway bar.
Don't you love a comment that begins with, "it depends"? Is your current suspension stock or sport and have you done any other mods to it? Are you wanting it race it or just go faster in the corners? As in cubic inches, going bigger is almost always good but....changing for the sake of changing can be expensive unless you like to wring out every lateral G force you can muster. If you're not a racer then I would say "no", most people wouldn't know the difference but if you like to drift in every turn then just about any upgrade from stock will be an improvement. That would be just the beginning though, tires, shocks, springs, brakes,...the list is endless.
Put the Hsport rear bar in and drive the car to see how you like it. You do NOT want to do a front bar and not change the rear that will make your handling worse and your car will push even more.
Way, is it even worth upgrading to an H-sport comp front sway bar? Everything seems to point to beefing up the rear as increasing the front sway bar size would increase understeer. Am I missing something here?
The stock RSB I took off my 2012 MCS this afternoon measures 17mm, I replaced it with the Alta 22mm rear sway bar. Originally I was thinking of going with the 19, but the guys at Alta said get the 22. Boy am I glad I did. Understeer is gone, the car feels much more solid and planted, it goes right where I want it without a hint of pushing or front tires scrubbing, and it is easy to adjust the line through the corner with the throttle. No drop throttle oversteer or other bad effects either. The car has gone from great handling to amazing. If you care about handling and you haven't upgraded your RSB, you gotta do this. Best bang for the buck mod out there.
In my R56 there's barely room for the 22mm, I'd be worried that the 25mm H-sport would rub. That's just my eye and my car, I know there are a lot of people who love the H-sport.
No Rubbing here.
I did it this way, and thanks to K_H_D I found out I have sport suspension.
I did the Hotchkis 25mm bar. Here is my how to if you need help doing ti yourself as it is pretty to do.
https://www.northamericanmotoring.co...6k-beware.html
