R56 Turbo Lag vs. Serious hesitation
Old Jan 30, 2013 | 05:03 PM
aboveliquidice's Avatar
aboveliquidice
I've purchased a new to me 2010 MCS hardtop with 20k miles. Pressing the accelerator from stop gives a considerable hesitation before acceleration. Pressing the sport button does improve it considerably, however the throttle is much higher and the shift points (both up and down) are more annoying.
I am concerned their may be an issue here. I also believe the cold rattle may exist as well. Just wanted to get a sense of how pronounced the Mini's turbo lag is. Reading online, it is not supposed to be very pronounced. It certainly is right now.
Old Jan 30, 2013 | 05:27 PM
Matty33's Avatar
Matty33
It sounds like there's more than there should be, I don't notice a great deal of lag unless you slightly push on the gas and let the rpms build up really slow. If you get on the gas pretty hard from a stand still do you get the same amount of hesitation?
Old Jan 30, 2013 | 06:57 PM
Melangell's Avatar
Melangell
2011 MCS with 20k+. No hesitation issues. Good luck.
Old Jan 30, 2013 | 08:28 PM
aboveliquidice
Interesting... I wonder if manual vs. auto plays into it. I have the step tonic auto. Thanks for the replies. Anyone else have an insight?
Old Jan 30, 2013 | 08:35 PM
ZippyNH's Avatar
ZippyNH
A MINI has such a small turbo, should have basically ZERO lag. unless it has been modified to a MUCH BIGGER aftermarket unit....
Old Jan 30, 2013 | 08:36 PM
Rejeme's Avatar
Rejeme
It hesitates from a complete stop or a rolling stop? Reason I ask is that my auto transmission doesn't seem to go into first unless I'm completely stopped, or maybe going 1 or 2 mph, no more. Other than that, it starts in second. Sport mode alleviates this condition.
Old Jan 31, 2013 | 09:14 AM
mbwicz's Avatar
mbwicz
One of the most annoying things about the MINI to me is the hesitation/delay in the throttle. My car is an auto (as was the justa before it), and I can duplicate the situation that you have described. Basically, the throttle is electronic, and there is a built-in delay time. The sport mode reduces the delay time, as well as increases the rate of throttle opening. There are products that eliminate/reduce the delay (sprint booster), and this is one of the things that my Accessport helped with a bunch.
I don't think it is turbo lag, just a delay in response to throttle input. Other than being annoying, there is nothing to worry about.
Mike
Colt45Magnus
Aug 27, 2024 05:03 AM
thadscottmoore
Jun 4, 2021 07:19 AM
schwac2
Sep 10, 2015 07:24 AM
kjd186
Sep 9, 2015 10:02 AM
Sep 3, 2015 01:45 PM
