FS:: parting 03 Mini Cooper base in SE, NC
Old Jan 29, 2013 | 07:02 PM
Morphius's Avatar
Morphius
Price: $900
Part fits (you may select multiples): R50, R52
Location (Region): SouthEast
I am throwing in the towel on my 2003 Mini Cooper base (71k miles) and turning my sights to fixing my 05 R52 S instead. The only thing wrong with the 2003 is the CVT transmission. I "thought" the trans jsut needed a seal on the input shaft, but found a small part of a tooth in the pan and can't see passing it on this way. It actually ran fine with fluid, never went dry, but the tooth sealed its fate.
I am just starting to part it out, and here is what I have for sale at the moment:
1.6L complete engine. THis engine has great compression and runs smooth and flawlessly. I would like $1200 out of the engine, but would take reasonable offers. I have it on fleabay, but reserve is high, would sell to member preferably. Engine comes with alternator, fuel injection and harness.
Dead CVT that can be used as a core. Perhaps this is a waste of time, but I have read folks need things like the valve body and other hard parts as well as it has about $500 as a core. I would like $350 out of it.
Both drive shafts. TheShafts have 71k on them, one (pass side inner boot) is split, I think I did this removing it, but that is a cheap repalcement. Like $75 for the pair, new ones are over 85 each as far as I can tell
ECU for the NA engine and CVT, would take $200 for it, maybe a little less
Front seats. They are the green interior I understand only came on the base model. They are in very good shape, the D/S shows a little wear on the leading edge like every one i have seen shows, no wear through at all. Like to get $200 out of them
Everything else is for sale. I will need to remove parts off this one to fix the 05, but everything less what I ahve to remove is up for grabs. Carpet, instruments, rear hatch, rear seats, doors, side windows, sunroofs, you name it. I will be using the front windshield in my 05 R52 (if it fits) and the airbag system (also provided it fits) and the D/S rear suspension. I'll probably keep the p/s pump cause they are so error prone. Let me know what you are intersted in. I am in wilmington NC. I can ship stuff within reason. Please text my cell if you want something cause I don't get to check this site very often given all my other comitments. it is nine one zero, two six four, two zero six zero. Or you can email me at rosbrughj followed by the at symbol, asme dot org. Text works best, again cause I can't always take a call with work, kids and a second job. Thanks. Jeff (Morphius - yes it is geeky Matrix thing)
Attached Thumbnails parting 03 Mini Cooper base in SE, NC-passrearquarter.jpg   parting 03 Mini Cooper base in SE, NC-r50engine1.jpg   parting 03 Mini Cooper base in SE, NC-zf_cvt_core.jpg
Old Jan 29, 2013 | 08:18 PM
blue2turbo's Avatar
blue2turbo
Email sent. Will text tomorrow! Thanks!
Old Jan 29, 2013 | 09:33 PM
minibuddy's Avatar
minibuddy
If the windshield does not work on your R52 ( which I do not think it will ), I will purchase it from you.
Let me know.
Old Mar 13, 2013 | 05:49 AM
Cooper14's Avatar
Cooper14
Is the alternator available and do you know if it fits an 07 cooper? Mechanic said I needed the number on it. Already ordered one and it was the wrong alternator.
Old Mar 15, 2013 | 01:13 PM
Morphius's Avatar
Morphius
sorry, alternator went to texas with engine.
I am trying to close this becuase my father bought the entire car from me and we are building him an unbadged s out of it and a roll-over we have that is a 40k mile s. I'll probably post details as we progress. Thanks!
Old Mar 16, 2013 | 07:36 AM
Cooper14's Avatar
Cooper14
alternator
Thanks anyway. Still searching for one. I can't find it anywhere. Neither can my mechanic. :( Still in the shop so went out and bought another mini.
Old Mar 20, 2013 | 09:29 AM
cargod4490's Avatar
cargod4490
pm'd
Mini'mon
Aug 16, 2015 04:15 PM
Aug 7, 2015 07:12 AM
Aug 7, 2015 07:11 AM
Aug 7, 2015 05:56 AM
