New Items Just Arrived
Just Arrived!
4-POINT SAFETY HARNESS
"A must for track-day, drivers ed, autocross, and enthusiastic street / canyon drivers!"
ENGINE DAMPER MOTOR MOUNT
"Improve performance by reducing 'torque loss' to engine movement."
LIGHTWEIGHT CRANKSHAFT PULLEY
"Power gains of up to 10%!"
MINI WINGS PROJECTOR
"Cast the MINI Winged Logo on the ground as you open your doors!"
REAR SUNSHADE SET
"A flexible tubular frame allows easy installation and removal."
PULLEY & IGNITION UPGRADE KIT
"Includes our -15% Supercharger Pulley with belt, MSD Ignition Coil, set of Iridium Plugs, 8mm Blue Plug Wires, and the Pulley Removal Tool."
FULL UNDER BAR REINFORCEMENT KIT
"Improve rigidity to reduce bodyflex when racing or to improve handing!"
ADJUSTABLE REAR SPOILER
"MINI Challenge type rear spoiler made of fiber glass reinforced plastic and aluminum. It has a carbon fiber look and the top vane is adjustable to three positions to increase/decrease rear down force."
STAGE 1.5 PERFORMANCE UPGRADE KIT
"This kit is all about improving the flow into and out of the engine. Increased flow into the engine creates stronger combustion and a less restrictive exhaust results in a more efficient engine."
PERFORMANCE SUPERCHARGER
"On a stock MINI with no other changes, the horsepower increase was measured at 197 hp from the stock 169hp, and torque to 163 lb-ft from 143 lb-ft!"
Alpha Motoring
Sep 7, 2020 07:34 PM
