Navigation & Audio X9331 Connector Issue with Windows
Old Jan 6, 2013 | 02:27 PM
redolphn's Avatar
redolphn
Hello!
Just did the channel swap and I'm having a big issue that I'm hoping someone can help with.
Ever since then, my windows will open when I open the car door as they're supposed to, however when I close the door, the windows don't go back up.
Is this controlled by the X9331 connector?
I disconnected the negative battery terminal to do the swap so is there a setting that I have to change?
Thanks in advance!
Old Jan 9, 2013 | 03:53 AM
Yehuda's Avatar
Yehuda
Anybody? What's happening with these windows?? What else goes through that connector? Has anyone else had issues after doing the channel swap? If you swap it all back, does the problem go away?
Old Jan 9, 2013 | 04:39 AM
yetti96's Avatar
yetti96
The windows might have to be reinitialized after pulling the battery. I think you press and hold the switch and keep holding it for a few (3-10)sec after it reaches the full travel. Do this for each window in each direction.
Old Jan 10, 2013 | 08:05 AM
redolphn's Avatar
redolphn
Sorry it's taken me a few days to respond...
I ended up doing the auto down/up on each window and it's back to normal now. Thanks for the help!
09R56
Nov 16, 2022 10:49 AM
woodstudio
Mar 15, 2020 08:28 AM
Toolman
Jan 20, 2016 06:50 AM
Bruce/Fl
Aug 28, 2015 11:59 AM
timwhayden
Aug 24, 2015 08:42 PM
