R55 Hill hold function
Old Dec 30, 2012 | 12:13 PM
John A Shook's Avatar
John A Shook
Hill hold function
Recently my 08 Justa developed a code and a yellow brake warning light. I have had the fault code cleared twice now and the light came back on. Seems to work, including the hill holder function, for a few days but comes back. My dealer is a couple of hundred miles away. Has anybody had this problem and if so, what was the corrective action? Any info would be greatly appreciated.
John
Old Dec 30, 2012 | 03:30 PM
jcauseyfd's Avatar
jcauseyfd
Could you post what the code was?
Old Dec 30, 2012 | 03:56 PM
John A Shook
Hill hold function
Sorry don't have the code but I'll find out Tuesday. For additional info, the hill holder worked after the mechanic reset the code but did not work when the yellow brake light came on again several days later.
John
Old Jan 4, 2013 | 06:09 AM
John A Shook
Hill Holder function
Did get the code for the malfunctioning hill holder function. It is DSC-5DBF. Hope this helps.
Thank you,
J. Shook
Old Jan 6, 2013 | 07:37 PM
jcauseyfd's Avatar
jcauseyfd
I haven't been able to find anything specific, but one site I found for BMW codes indicates that code is for a "Hydraulic unit valve : USV1".
My best guess is that you either have a sensor going bad that is causing the fault or you actually have some part failing in the brake system. I guess if the code is somehow related to hydraulics, it could be due to some problem like the brake fluid needing to be replaced or low if you haven't had it bled lately.
Unfortunately, I have a feeling you are going to have to make a trip to the dealer.
Old Jan 6, 2013 | 08:19 PM
John A Shook
Hill holder function
Thank you very much for taking the time to research this problem. It is greatly appreciated. My first attempt will be to go to my local tech and provide him with the info you provided. If that doesn't bear fruit, off to the dealer in Richmond, Va as I don't care for Flow Mini in Raleigh, NC. Again, thank you
J. Shook
Filmy
15
Jun 6, 2023 06:27 AM
Camden90240
Sep 28, 2020 12:09 PM
riff42
Sep 22, 2015 03:07 PM
MINI-Madness
Sep 11, 2015 11:31 AM
Accessory Products
Sep 10, 2015 11:38 AM
