Navigation & Audio Aftermarket deck
Aftermarket deck
I have a 2009 Mini Cooper with the boost deck in it. Am i going to be able to change the deck to an aftermarket one without it messing with all the factory components. I recently got an amp and sub but the back of the boost deck does not have the av cable hook-up. Will i be able to change out that portion with a kenwood touchscreen deck with the av cable hook-up on the back?
it can be changed out not too much of a hassle. I desided to ditch the display for now waiting on Escort 9500ci intedgrated radar detector display will mount there. I fyou want toMaintain chimes Metra makes the wiring Kit. There dash piece is very nice as well. Myself I decided I didnt need chimes so I left the factory Harness be and ran separate Power, ignition, ground, and remote wires.Ill post a pic when I go outside today getying ready to build new box for 4 SA-8 subs
Everything that is controlled in speedo dislplay can be done in the HUD just a little less convienent. There is a thread on here with a member who relocated stock head unit and kept everything else alone.
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
