R50/53 Megan Coilover Questions!
Old Dec 24, 2012 | 11:05 AM
suntaepark's Avatar
suntaepark
anybody got Megan Coilovers???
It seems too cheap for $1000 coilovers with all that fancy stuff.
Is there any quality issues? fitment issues? or anything?????????
please help!
Old Dec 24, 2012 | 12:03 PM
dannyhavok's Avatar
dannyhavok
http://bit.ly/LwdOZp
Lots of threads on this. ST is another good option for that price point.
Old Dec 24, 2012 | 12:28 PM
mini562's Avatar
mini562
I just installed ST coilovers two days ago with 5mm front spacers, Hotchkis camber arms and love the setup.
Old Jan 2, 2013 | 08:10 PM
minime331's Avatar
minime331
I got a set of Megan CO for the price you get a good set of co I got them bc I'm a college student and I wanted a good set at a good price and kw and others were more $$ and were out of question. The one problem I have is when adjusting the hight, the top nut would come losses causing the strut to make a knocking noise. The easy fix is to put lock tight on it an tighten it back down
Old Jan 4, 2013 | 04:35 PM
Thinker2112's Avatar
Thinker2112
You are a friggin' genius! That is my problem with my Megans! The top nut under the adjustment **** is about 1 cm lower then the other one!
Other than that, I really like mine. Came with the extension cables for the rear’s - those will go on this summer. They say 32 different adjustment settings, so I put them right in the middle 17. Way to hard for normal street use. With my summer tires, ride is not good, very harsh. With the winter tires, the ride is better, but the suspension overwhelms the skinny tires with tall tread. They will be softened up soon. Or I could just drive slower…
Old Jan 4, 2013 | 06:40 PM
minime331's Avatar
minime331
You can take the adjustment **** off to get a better grip of the top bolt
Old Jan 6, 2013 | 03:59 PM
Thinker2112
Thanks minime331! everythinging is 100% now! Super easy fix.
So, thoes of you out there thinking of these or any other aftermarket part - check ALL nuts, screws, et al, prior to and post install. I do like the Megans. You do get a lot for the money.
donniedarko
Oct 21, 2015 01:15 PM
molala
Oct 2, 2015 01:53 PM
one73ronin
23
Sep 22, 2015 09:56 AM
rob76turbo
Sep 15, 2015 10:11 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
