R60 Front Small Overlap Crash test - How well do you think the CTM will do?
Old Dec 22, 2012 | 07:34 AM
preme123's Avatar
preme123
Front Small Overlap Crash test - How well do you think the Countryman will be able to perform the test?
Judging from the structural design of our car, and the materials used, do you think it will score high? Since they didn't perform the test on a countryman yet...
example of the crash test below... yikes! looks scary to me
https://www.youtube.com/watch?v=gOOMR-fTBWg
Old Dec 22, 2012 | 07:40 AM
nickkoto's Avatar
nickkoto
I'm not planning to get into one of those.
Old Dec 22, 2012 | 08:16 AM
ghamma's Avatar
ghamma
I looked into this when the test was first announced. It's easier to see the structure in some of the stripped-down ProDrive photos. There are two strong pieces sticking out the front. If my measurements match those used to set up the tests, the CM could do OK. I've got drawings around here somewhere...
<Image Uploaded>
Note that the strong parts that stick out from the firewall are within the 25% range and should help the CM perform well on that test. They certainly helped when Fenton met the Odyssey. The target is rounded on the part intruding most into the car, though, and it could bounce off the strong bits and push the tire and supports into the driver's side.
Attached Thumbnails Front Small Overlap Crash test - How well do you think the CTM will do?-cm25percent0001.jpg   Front Small Overlap Crash test - How well do you think the CTM will do?-small-overlap-overhead.jpg
W0TM8
Dec 19, 2019 07:50 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
FLYM1N1
Aug 15, 2015 11:20 AM
