R56 Water Pump and Timing Chain change:
Old Dec 10, 2012 | 01:37 PM
JohnsD90's Avatar
JohnsD90
So before i get flamed to read all the other threads and search, i have, and i still cant get a definetive list on what specific parts i need to change the timing chain, tensioner, and water pump. I have the rattle expierenced with these R56's and i would like to sort it out sooner than later. I'm on numerous other forums and its easy to find a timing belt or chain kit for my tdi or Land Rover, but this its pretty brutal for such a talked about topic to get a list.
So i stopped by my local mini dealer to get a list of what i need, and they gave me this long list with a bunch of bolts and gaskets on top of this. Ive changed timing belts before and generally i dont change bolts and gaskets but i understand that was the stealers take on it.
My question is, What parts do i need, and what are the part numbers, i would like to get the new chain, and the tensioner, not the tensioner for the stretched chain, and i will also be changing the water pump while i am in there.
Can anyone help with that? Thanks! Photo of the parts list that mini gave.
Old Dec 10, 2012 | 05:52 PM
gregsmini's Avatar
gregsmini
I would go to Way Motor Works and buy their timing chain replacement kit for $399: http://www.waymotorworks.com/timing-...-cooper-s.html
and timing tool kit for $299: http://www.waymotorworks.com/timing-...7-r58-r60.html
and water pump for:$150 http://www.waymotorworks.com/water-p...8-r59-r60.html
Now, if I can only get Way to send me a commission!
I found the tool cheaper on amazon, $175:
Amazon Amazon
I guess the commission is gone for sure!
Please check that these are actually what you need!
I expect to do the same thing in the spring, so you should be able to sell the timing tool to recover some of the cost!
Old Dec 10, 2012 | 06:21 PM
JohnsD90's Avatar
JohnsD90
Thats more than Mini quoted me.
Old Dec 11, 2012 | 08:30 AM
JohnsD90's Avatar
JohnsD90
I found the tool cheaper on amazon, $175: http://www.amazon.com/Cooper-Engine-.../dp/B00784QX52
I was told the Timing tool kit was not required, and if you look, the sheet the dealer gave me was cheaper than that kit!
Old Jan 1, 2013 | 02:36 PM
sparkyjim's Avatar
sparkyjim
Thanks for posting the list; out of curiosity, what did the dealer quote you for a price to replace the chain & tensioners, etc??
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
kwijmbo
Aug 5, 2015 09:00 PM
