Electrical High Beams and fog lights at same time
Is it possible to have the High Beams and the front fog lights on at the same time? Perhaps coding in NCS Expert?
I have seen on other BMW boards the following value on LCM module, but not sure if it is the same on R56:
I have a 2008 Mini Cooper S.
FL_UND_NSW_NICHT_GLEICHZ - front fog lights not simultaneously with high beams
aktiv
aktiv
Sorry, not an NCS expert but I'm sure there must be some way to do it by merely making a few wire splices. I presume you're running oem fogs and driving lights. All you need to do is convince your fogs to stay on anytime the switch is on and the parking lights are on (vs low beams).
Thank you very much.
Apparently I need to set these to nicht_aktiv. I was checking and I had them aktiv already in FRM module.
http://www.bimmerfest.com/forums/sho...21&postcount=9
If you are not going to use them as fog lights then they might help a little as high-beam helpers.
This is a sensitive topic, how dare someone want to use high beams and fog lights, how about high beams, driving lights and fogs ALL at the same time?
I like as much light as possible when driving on a dark road. Just my opinion.
Dec 23, 2015 10:36 AM
Aug 7, 2015 05:55 AM
