timing chain repair dilemma
Old Nov 14, 2012 | 06:15 AM
Yslee's Avatar
Yslee
my chain is failing and the service adviser from the dealer quoted me $1800. An Independent (specializing mostly in BMW) mechanic quoted $1100. I don't know if the indy mechanic has ever replaced the timing chain for the MINI. but I have more wiggle room for negotiation with the indy mechanic since I bring all my other BMWs to him for repair and upgrades.
What do you guys think? should i stick with the dealership who has done this job many times for a premium price or go with an indy mech who's very competent with his skills?
If I go with the the indy mech, do you know exactly what parts needed to be ordered? (esp. updated tensioner pulley)
Old Nov 14, 2012 | 06:46 AM
Helix13mini's Avatar
Helix13mini
You should get some clarity on what 'chain is failing' means. If your symptoms are a clattering engine, It could be a bad tensioner, bad chain guides or poor oil pressure. In my experience, the chain doesn't slowly fail (as in: 'it's failing'). It's either good, or it's broken.
Old Nov 14, 2012 | 07:03 AM
Yslee's Avatar
Yslee
service adviser told me that the slack on the chain is a lot and the clatter is pretty bad. No engine light yet.
Old Nov 14, 2012 | 07:18 AM
Helix13mini
The slack in the chain is removed by the chain tensioner and guide rail assembly. Those parts are cheap enough that I might try replacing them before submitting to a chain-ectomy. With the guides removed, the lash in the chain could be measured. As I said, I haven't seen where the chain stretches significantly.
Guides and a tensioner should be a bit over $100, and labor (at our shop) would be about $250. Looking into my crystal ball, I see a third opinion in your future!
Old Nov 14, 2012 | 08:12 AM
Yslee's Avatar
Yslee
Thanks for your advice. I know that there has been several updates on the tensioner. Do you happen to know the part number for the newest one?
Old Nov 14, 2012 | 08:18 AM
Helix13mini
Search here.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
makg
Aug 21, 2015 02:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
