Winter is here, it's time to weather up your MINI
Old Nov 12, 2012 | 10:21 AM
Mini Mania's Avatar
The Weather Is Here...are you prepared?
Is your MINI ready for winter weather? Check out our list of must-haves for this winter wonderland!
Wiper Blade Rear Oem R50/53/55/56 Cooper & S.
Factory replacement REAR wiper blades. Different rear blades available for: 2002-2006 R50 Mini Cooper and R53 Cooper S Hatchback 2007+ R56 MINI Cooper and Cooper S Hatchback 2008+ R55 MINI CLUBMANs Make selection - these blades are 'production date' dependent. Check the manufacture ...
Wiper Blade Set Front Pair Oem R50/52/53/55/56/57 Mini Cooper & S.
Factory replacement wiper blade set. Includes both right and left hand wiper blades. Fits the following models: 2002-2006 R50 MINI Cooper Hatchback 2002-2006 R53 MINI Cooper S Hatchback 2005-2008 R52 MINI Cooper and Cooper S Convertible 2007-2013 R56 MINI Cooper and Cooper S Hatchba...
Einszett 'kristall Klar' Washer Fluid Concentrate 250 Ml.
German car care technology at it's finest! Kristallklar Premium (Windshield Washer Fluid) • Concentrated windshield washer fluid cuts through grime, insects, sap, and grease better than the common 'blue washer fluid'. • Lubricants in formula extend wiper life and prevent skipping. • Squ...
Driving Rally Lights Pair R55/56/57 Mini Cooper And S.
Factory Driving Lights for your MINI! You don’t have to compete in rally racing to outfit your MINI like one. These sporty driving lights will brighten the way on the darkest night. They work with the standard high beams and have a separate on/off switch for use at your discretion. Brackets and Swit...
Tpms Tire Pressure Monitor System Set Of 4 Mini Cooper & S.
A set of 4 sensor/transmitter with special valve stems that works with the new Tire Pressure Monitoring . These are the genuine Beru brand parts used by the MINI factory. This TPMS kit is compatible with the following models: 2007-09/2009 R56 Cooper and Cooper S Hatchback 2008-...
Headlight Bulb Replacement H7 Ea R50/52/53 Cooper & S.
Replacement H7 headlight bulb for the High and Low Beams on MINIs with the Standard Halogen Headlights. Sold Each. MINIs with the 'Standard' Halogen Headlights uses the H7 bulb for both the High beam and Low beam. This means 2 per headlight - 4 total for the car. Fits the following m...
Car Cover Indoor Or Outdoor R57 Cooper & S Convertible.
Custom Fit Indoor or Outdoor car cover for your 2009-2012 R57 MINI Cooper and Coopers S Convertible. Indoor Cover The accessory of choice for the motorer who: (a) plans on garaging their MINI for extended periods of time and/or (b) wants to keep every last dirt and dust particle off their MINI...
145/70 12" Winter Tire Grips Well In Snow.
Driving a Mini in the snow is always great fun and now it can also be safer with these special tires designed for winter driving! 145/70-12" STEEL BELTED RADIAL tires (E4 rated) are the stock size on most all later models of the Mini. They are a great on stock 4.5" rims and will also fit 5". ...
Fog Light Kit R50/52/53 Mini Cooper And S.
These Fog Lights on a MINI Cooper will provide great looks not just from the outside in but more importantly from the drivers point of view. Quality fog lights can make you a safer driver in inclement weather and help you avoid the blind spots. Fog can be a real problem when you are driving a small...
Compact Emergency Spare Tire W/bag 15 In R50/52/53/55/56/5.
Space-Saver Emergency Spare Tire with a heavy duty Storage / Carrying Case! COMPACT EMERGENCY SPARE TIRE - Factory unit If you switched from run-flat tires to standard tires, here is the spare designed for your MINI. Beware of 'similar' space-saver tires from other brands since the hub ...
Floor Mats Black Rubber Pair W/logo Oem R56/55/57/58/59 Cooper & S.
Just like your MINI COOPER, these durable black rubber floor mats provide form and function. With a distinctive pattern and logo (on fronts) for style, the floor mats vertical grids funnel moisture to improve footing. They are perfect when motoring in mud or snow. Sold in Pairs - Front pa...
Dec 23, 2015 10:36 AM
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
Dashdog
Aug 10, 2015 06:17 AM
