R50/53 Clunk in rear, need ideas
Old Nov 8, 2012 | 11:08 AM
davisflyer's Avatar
davisflyer
I have a clunking sound coming from the rear going over bumps. I jacked the car up and checked the suspension and exhaust and everything seems tight. Added electrical tape to the hatch loop as well. Still have the clunk. It's driving me crazy because I can't seem to find anything amiss.
Old Nov 8, 2012 | 11:18 AM
OldGameFreaK's Avatar
OldGameFreaK
snug down the end links on the rear sway bar. if they are tight then replace the sway bar bushings.
Old Nov 9, 2012 | 08:43 AM
thulchatt's Avatar
thulchatt
Could be the rear shock mount bushings.
I chased a similar sound for months. Thought it could be anything from the sways to the one-ball mod bouncing.
Turns out it is the upper shock mount.
Way at WayMotorWorks helped me with this.
He is also sending me:
- Koni FSD shocks
- Powerflex upper shock mount bushings
- Ireland fixed comber plates
- Powerflex control arm bushings
- OEM front sway bushings
Old Nov 9, 2012 | 01:36 PM
davisflyer's Avatar
davisflyer
Thanks guys, I will check these out!
Old Nov 9, 2012 | 06:19 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Mine are doing it too. I narrowed it down to the rear strut top mounts. Everything else is tight and in good shape.
The clunk is only over pronounced ridges in the roadway, never depressions.
Old Jan 27, 2013 | 08:56 PM
davisflyer's Avatar
davisflyer
It's not the rear strut top mount bushings, they still look new.....I'm leaning toward the RSB bushings now. Will update after I check those..
Old Jan 28, 2013 | 01:40 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Don't be mislead by looks alone. Run over with a spanner and check for cracks and splits. That noise is comming from somewhere.
Old Jan 28, 2013 | 06:27 AM
thulchatt's Avatar
thulchatt
If its not the strut top bushings it probably is the sway bars.
That is the much easier and less expensive fix.
Old Jan 28, 2013 | 10:14 AM
BSTINS's Avatar
BSTINS
I've got that same sound. Not looking forward to pulling the rear strut to check the mount. I guess I'll do what I have to do.
Old Jan 28, 2013 | 01:43 PM
Spooled's Avatar
Spooled
It's an extremely easy DIY. Remove the wheel. Remove the lower strut mount bolt. Remove the top two strut mount bolts, and you're done.
Old Jan 28, 2013 | 03:01 PM
thulchatt's Avatar
thulchatt
Unless you have to replace the strut mounts. (But you are correct to check is not that hard)
If you are going that far, you likely need struts also.
So, then you are in a little deeper even though you are correct with what you have written.
Old Jan 28, 2013 | 10:36 PM
BSTINS's Avatar
BSTINS
I'm already running on bilstien struts with h-sport springs. I have this week off work so I guess that will be my project.
Old Jan 29, 2013 | 12:15 PM
opticspen's Avatar
opticspen
I do hear some sound from the rear when I release gas paddle quickly after an acceleration
the car sometime have a slight jerk sometime not, but can easily hear some sound from the rear area
is the sound from pipe, or some other things?
Old Jan 29, 2013 | 04:24 PM
Enzof104's Avatar
Enzof104
I've got a similar sound. Close to a rattle and I can't tell the side of the car. I replaced the upper shock bushings and the rear sway bar and bushings. I even had my wife drive the car in the driveway while I sat in the open boot. It's been driving me nuts for months.
Old Jan 30, 2013 | 10:54 AM
davisflyer's Avatar
davisflyer
Problem solved!! Boy, I feel stupid. Instead of looking at the easiest possible fix, I took the hard route, taking apart rear suspension looking for worn strut top bushings and RSB bushings to no avail. Clunking was driving me nuts and everything was good and tight.
Yesterday I replaced my rear hatch supports. When I went for a drive I noticed about a 50% reduction in clunks....hmm. So I go back and adjust the rear hatch bump stops which when twisted counter-clockwise they increase their depth. That helped some more. Kept adjusting (a lot!) and finally reached about 98% reduction on the clunking. I'm not sure what else I can adjust, but at least I wont be driven nuts by an occasional clunk.
Old Jan 30, 2013 | 11:00 AM
bahawton's Avatar
bahawton
Thanks Davisflyer- I'm going to have to check my hatch bump stops since I have a similar problem.
Old Jan 30, 2013 | 11:11 AM
BSTINS's Avatar
BSTINS
Do you have a photo of the rear hatch bump stops you are referring to?
Old Jan 30, 2013 | 11:39 AM
LethalR53's Avatar
LethalR53
This is intresting. I might be tackling this on the weekend, if only I knew just exactly what hatch bump stops or supports are :/
Old Jan 30, 2013 | 02:07 PM
davisflyer's Avatar
davisflyer
Part #6 on the inside of the hatch door.
Old Jan 30, 2013 | 02:11 PM
BSTINS's Avatar
BSTINS
Thanks for pointing it out. I know exactly what you are talking about.
Old Feb 1, 2013 | 12:41 PM
MOWE's Avatar
MOWE
Its funny..i have that same sound from the front and rear...but only in the morning when I first start it up and go over the first two speed bumps in my area...after that never feel / hear again...lol..but every morning it happens
thoughts ?
Old Feb 4, 2013 | 04:50 PM
davisflyer's Avatar
davisflyer
Sound is back. Tried driving on a rough parking lot with the hatch open and it still does it.....back to square one
Old Feb 6, 2013 | 04:28 PM
opticspen's Avatar
opticspen
I get very similar sound as yours, any clue, I'm inclined to believe it's not the tail gate.
I rolled out the window once trying to hear where the sound comes from, actually I feel it comes from the rear wheel area, which worries me a lot.
any inputs will be highly appreciated.
Old Feb 6, 2013 | 06:42 PM
MINIFatherFigure
opticspen - all of the above - except the tailgate.
Old Feb 6, 2013 | 07:02 PM
Enzof104's Avatar
Enzof104
So I figured out my issue. I had a bad end link on my sway bar that needed replacing. Easy fix and made a world of difference. Now I have to try and fix that annoying sunroof squeak.
