R56 Mini-Generator
Old Oct 30, 2012 | 02:15 PM
Electro's Avatar
Electro
Mini-Generator
So, I'm in NJ without power. Looked at a generator in the Home Despot about a week ago and said, 'nahhh'. Doh!
But I have a Mini (2009 S), and a 300W power convertor connected to the Cigarette lighter.
Running a lamp, a fan on the fireplace, and charging a few items.
It's been purring in the garage all day (yes, the door is open), giving me juice. The gas gauge hasn't moved yet.
Might be a dumb question but, any issue with letting it idle for 8 hours?
I really don't think so, but thought I'd ask anyways.
Thanks,
Val
Old Oct 30, 2012 | 02:55 PM
chrunck's Avatar
chrunck
The engine may overheat since no air is being blown over the radiator. Opening the hood is probably a good idea.
Old Oct 30, 2012 | 04:16 PM
Electro's Avatar
Electro
Thanks, been checking that. The electric fan kicks in every once in a while, but as it's about 40 out, I think it's doing ok.
Finally saw one light go out on the gas gauge.
Note: Don't try to connect a refrigerator to one of these convertors. Was pretty sure it wouldn't work, and figured on a blowing a fuse. I was right. 20amp Fuse #29 in the passenger fuse compartment.
Old Oct 30, 2012 | 05:23 PM
daflake's Avatar
daflake
Couple of things...
First, you take a chance at killing your motor as the oil pressure will be minimal. Not a good idea. You are also putting heavy duty on your fan thus cutting its life.
Secondly, running motors on those converters is also asking for a fire. They are not designed for high duty cycles, only minor things.
