R56 2010 MCS Alarm Questions
Old Oct 28, 2012 | 08:20 PM
avuton's Avatar
avuton
Hello,
I bought a 2010 MCS a few weeks ago, last owner told me there was an alarm on the car. Seen as how I haven't seen the LED on the tachometer blinking after locking I began thinking he was incorrect, so I shook the car after locked, pretty hard and no noise .
Question is: What's the easiest way (other than the shake method) to confirm I don't have an alarm in the car ?
Second thing, I know the factory installed alarm is different than the retrofit alarm, but I can't find anywhere what the difference would be.
Old Oct 28, 2012 | 08:56 PM
aznqtboy984's Avatar
aznqtboy984
Does it chirp when you lock or unlock the car?
Old Oct 28, 2012 | 09:05 PM
avuton's Avatar
avuton
No, it doesn't. Makes sense, but I thought I read that wasn't a sure sign. Thanks
Old Oct 29, 2012 | 02:18 AM
Summons's Avatar
Summons
I would confirm the alarm with the previous owner - the LED on the tach is the main indicator - I have the chirp shut off on my '12 MCS, but the tachometer LED remains.
That being said, I am assuming the '10 is the same...
Old Oct 29, 2012 | 07:19 AM
yetti96's Avatar
yetti96
The chirp can be turned on or off and set using the BC stalk button, similar to the 1 or 3 blinks, lock setting, light setting, etc. If the option for the chirp isn't in there and no LED...you def don't have an alarm from the factory.
Old Oct 29, 2012 | 08:47 AM
schatzy62's Avatar
schatzy62
The best way to tell is to pull the roof console off above the mirror the MAIN module for the alarm system is up there. It is a black box that snaps into the plastic under the cover.
Item #2 in this picture is what sits up there.
http://www.realoem.com/bmw/showparts...66&hg=65&fg=60
And it sits up inside Item #3 in this picture.
http://www.realoem.com/bmw/showparts...00&hg=61&fg=35
If it is not there then there is no OEM alarm installed.
You may want to check with the previous owner about and aftermarket alarm though.
Old Oct 29, 2012 | 08:30 PM
Melangell's Avatar
Melangell
Set the alarm with the windows rolled down and have a June Bug fly through. Worked for me!
maniacalmorgan
38
Sep 29, 2015 04:56 AM
Miniwaukee
Aug 24, 2015 01:52 PM
smarsha11
Aug 24, 2015 06:03 AM
nomar116
Aug 10, 2015 11:24 PM
