Clear Bra, Paint and Headlight Protection Sale 30% off
Old Mar 30, 2004 | 06:26 PM
Auto Paint Guard's Avatar
Auto Paint Guard
Paint and Headlight Protection:
The clear invisible bra is a pre-cut 3m Film that fits specifically to your make and model. The clear bra comes with a 4-year warranty and a $1000 paint protection guarantee. The bra is virtually invisible and protects from rocks, bugs, and road debris. The bra covers the hood, mirror, grille, bumper, headlights and other areas of the vehicle.
http://www.xpel.com - 30% off
The complete kit comes with headlight protection and has more protection overall. You can order seperate pieces as well. The xpel kit also is a cleaner looking bra, due to fewer cuts in the material. Down side is I would recommend an installer to do the install. There is a shopping cart on the website for quick purchases. http://www.autoclearguard.com/paintmini.htm
http://www.Invinca-Shield.com - 10% off
The complete kit for a MINI is $160 Shipped. The invinca-shield kit covers a little less than the x-pel kit but is a lot easier to install for the customer. The kit comes with instructions and a video on how to install. Invinca also has other pieces as well.
Tag Trim- $6
Cab Top- $29
Door Pillars- $29
Mirrors- $7
Rear Bumper- $16
Door Edge Guards- $4
I will be more than happy to also find an installer for you. Installation cost anywhere from $150-$200.
Maintance Tips:
Make sure you wax your bra at least once a month with a polish wax. This will allow cleaning the bugs off easier and make the film shine and last longer. Otherwise, pretend the bra isn't there and wash your car.
E-mail Ryan@autoclearguard.com
Ryan Burroughs
813-505-3868
Old Apr 8, 2004 | 07:49 PM
Auto Paint Guard
I thought this would help a lot of people with questions. Below are some questions that people have. Let me know if you have any additional questions.
Can it be removed?
Yes. It can be removed easily and will not damage the paint. To remove the film, you must heat the surface to approximately 150°F while working a corner of the film with your fingernail. Once you have enough of the material free from the surface to hold on to, slowly pull the film from the paint.
Will it really stop rocks from chipping the front of my car?
Yes. The material that it is made from was originally designed by 3M engineers to protect the leading edges of aircraft propellers and rotor blades from rock chips. It is a much easier task to protect your vehicles paint than it is to protect a propeller moving at nearly the speed of sound.
Can I see a line where the shield stops?
A line is slightly visible where the shield stops, but the three alternatives to that line are a bug shield, a bra, or rock chips.
How hard is it to see on the car after it is applied?
The material is about 99.5% clear. On any color darker than stark white, you can't see the film. On a stark white car, you can see that .5% of color, but it still is "invisible" at a short distance.
How long will it last? When will I have to replace the kit?
Our product is warranteed for 5 years, though the material has an average life span of about 7 years. Except for rock chips, the same factors that affect the life of your cars paint affect our product. Whether or not the car is garaged and whether or not it is kept washed and waxed will make a big difference.
How is the kit applied? Do you spray it on?
The plastic material comes to us in a large roll. Our machines cut the plastic into shapes designed to fit various parts of your car. These pieces are then applied to the vehicle in a very similar fashon to that of window tint. The pieces and the painted surface are wet with a solution and moved into position, then the solution is squeegeed away.
Will my paint fade differently under the shield than it does on the rest of the car?
No. The material does contain an inhibitor to prevent the plastic from reacting to the sun's UV rays, but this does not prevent the UV rays from passing through the plastic into your paint.
Is this material safe to use on the new water based acryllic paints that are being used by some manufacturers?
Yes. The material has no harmful effects on water based acryllic paints and still provides the same level of protection.
Dec 23, 2015 10:36 AM
Bennyboy
Aug 18, 2015 07:28 AM
Powershift
Aug 16, 2015 05:14 PM
ludedude
Aug 10, 2015 07:16 PM
bctf1
Aug 6, 2015 12:55 PM
