R50/53 Engine oil leak sealers question ???
Old Oct 24, 2012 | 06:38 AM
choupette's Avatar
choupette
I have a potential rear main seal leak,don't know exactly if it is the rear main that's leaking so I was thinking first before I spend a fortune on repairs if I was putting a can of engine sealer first or thicker oil grade, (right now it's got castrol 5w30),could it be the source of my leak, is Castrol any good, anybody tried the engine oil leak sealers for the Mini, can somebody help me out, thanks guys !
Old Oct 24, 2012 | 07:19 AM
ZippyNH's Avatar
ZippyNH
Sealers, are usually just a chemical that makes shrunken seals and gaskets swell...it is temporary in that the gasket/seal will shink, sometimes to a smaller size when it is not used....so it becomes like a drug addiction for a car. Some "high mile" older car oil has a bit in it....so the stuff is a mixed bag...if a seal is physically bad, cracked or torn, this stuff will not work. The additional negarive is ALL gaskets in the motor is getting bathed in this stuff...not just the one you ned fixed.
Mini's have some common leaks....safe to say those common ones have been looked at? Syenthic oil (100% needed imo) does flow, and makes leaks look very bad....it can be blown around too...
Old Oct 24, 2012 | 10:05 AM
Noir2005's Avatar
Noir2005
Not only that, but when standard seals that aren't leaking absorbs this, they will stretch and become weak when the product is no longer used, and can distort baskets, making them leak, or need replacement.
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
elightbo
Aug 17, 2015 01:50 PM
azntaiji
Aug 13, 2015 03:24 PM
