R56 Power outage MINI R56 diesel
Old Oct 16, 2012 | 11:47 PM
roosm's Avatar
roosm
Hi,
I have a 2008 MINI R56 Diesel that didn't start after start/stop a couple of weeks ago. When I pushed my clutch down to get it to start everything just died. No electricity anywhere. I pushed it to a gas-station and tried looking for a blown fuse in the engine compartment. Didn't find any, but when I closed the hood it came back to life. Ignition on with me outside, key in pocket.
I thought I might have solved some bad contact when I handled the fuses.
Last night when I got home and parked the car, my key wouldn't come out after shut-off. No dome-light, nothing. I figured it was the same problem. I then popped the hood, stepped out and pulled the largest fuse. Re-inserted it. Nothing. Then I figured it might have been when I closed the hood it started, so I tried that again, with just a little extra force, and the car came back to life!
Guessing I have a glitch somewhere?
The connections on the battery are obvious to check. What else?
Mike
Old Oct 17, 2012 | 04:42 AM
ZippyNH's Avatar
ZippyNH
Since there is not a single mini diesel in the us (90% this site), you ight want to try a euro centric mini site....most any suggestion will be a guess..most likely worse than the typical guess on an auto site!!
Old Oct 17, 2012 | 02:31 PM
Slave to Felines's Avatar
Slave to Felines
I would guess at a bad connection on the battery.
Old Oct 19, 2012 | 05:20 AM
roosm's Avatar
roosm
Both battery connections were loose. Very loose. I fixed that and hopefully it was all that was to this problem. I'll check back here if it happens again.
Thanks,
Mike
Dec 23, 2015 10:36 AM
xpunisherx
Aug 10, 2015 10:50 PM
marendt428
Aug 8, 2015 04:44 AM
USA-RET
Aug 6, 2015 09:22 PM
