Hotchkis Suspension Sale
About Hotchkis
For discriminating mini drivers who demand the best, Hotchkis has the improved suspension products that dramatically increase the pleasure of your street or track driving experience. Serious drivers understand the benefits of a properly engineered aftermarket suspension include increased stability, improved handling, and maneuverability. In keeping with their “Making a Great Car Even Better” theme, Hotchkis suspension packages give you a comfortable ride as well!
2002-2006 Mini
Front Sport Sway Bar, Part # 22800F MSRP $346.25
The Hotchkis Sport is a tubular front sway bar for the 02-06 Mini. Two-position adjustable, this bar perfect for those who want to dramatically decrease front roll while at the same time, transforming the initial steering input from fairly vague to very precise. The Hotchkis Front Sway Bar comes complete with polyurethane bushings, bushing brackets and zerk fittings for easy, occasional lube. The sway bar is powder coated brilliant black for sharp looking, long lasting upgrade.
Specifications:
27mm diameter hollow bar
Adjustable to 16% or 27% stiffer than stock
Rear Sport Sway Bar, Part # 22800R MSRP $308.75
The Sport Rear Sway Bar is a 3-position, 19mm, tubular sway bar. Recommended for street and track use, the Sport Rear may be used in combination with the stock front bar. All three settings on the Sport Rear are very useful if you attend track days, yet the bar itself is perfectly suitable for daily street use without any harsh ride effects of a larger bar. The Sport Rear adjusts easily, in most cases it may be accessed directly through your rear wheel spokes! The set comes complete with polyurethane bushings, bushing brackets and 90-degree zerk fittings for easy lubrication.
Specifications:
19mm diameter hollow bar
Competition Sway Bars
Rear Sway Bar Part #22810R MSRP $336.25
Front & Rear Set Part #22810 MSRP $682.50
The Hotchkis Competition Rear is a massive 25.5mm, tubular, 4130 chrome moly sway bar weighing in at only 5.5 pounds! Recommended for competition use only, the bar has three adjustment positions with the softest setting being the more neutral balance. From there, the middle setting will really aid the Mini medium to long mid-corner speed where there will not be any throttle feathering needed to turn the car. The stiffest setting is most beneficial through very slow, tight corners where without the bar you'd find yourself on and off throttle several times. With the Competition Rear this type of corner should need only one steady throttle application. Although handling characteristics may vary depending on your set-up, each position of the Competition Rear is very distinct and useful. Now you have an advantage at the track and auto-cross course! The set comes complete with polyurethane bushings, bushing brackets and 90-degree zerk fittings for easy lubrication.
Go all the way with the complete Competition set. Utilizing the 25.5mm Competition Rear and the 27mm Sport front, the Competition Sway Bar Set is most suitable for track day events on road courses. Both front and rear are multi-adjustable for fine tuning grip levels entering and exiting corners. With this set installed, the Mini will turn-in very quickly and roll very little before it takes a set which it will maintain through the corner. With two positions at the front and three at the rear, there is plenty of adjustability to dial-in the most demanding road courses.
Specifications:
27mm diameter hollow front bar
25.5mm diameter hollow rear bar
Adjustable Rear: +226%, +294% & +383% stiffer than stock
2-Piece Sport Rear Camber Links Part #13800 MSRP $370.00
Hotchkis Rear Camber Links are perfect for lowered Minis. Camber links are adjusted by loosening the lock nuts and then rotating the hex center for 0 to -4 degrees camber. The Hotchkis Camber Links are designed and tested to suit any street or track environment. Each link comes fully assembled and pre-set to stock length. This allows you to use that as a camber baseline and then you adjust out from there. The Links are made of two tubular steel outer arms with a billet aluminum hex center. The polyurethane bushings can be greased via the zerk fittings at each end. Durable and highly functional, the Sport Camber Links give you the freedom to set the rear camber to suit your driving style.
4-Piece Competition Rear Camber Links Part #13810 MSRP $698.75
Hotchkis Competition Rear Camber Links are designed for those competitors that want that extra bit of rear adjustability. Essentially the same as the 2-piece Sport Set but with an added pair of links. The second pair of links replace the upper arms and are fully adjustable as are the lower Links. This allows the rear track to be adjusted slightly enhancing the overall grip level in the rear through a corner. Each Competition Camber Link set comes complete with the fully built arms and a stability sensor bracket for those with that option on their Minis. The links are made of two tubular steel outer arms with a billet aluminum hex center. The polyurethane bushings can be greased via the zerk fittings at each end.
2007-2012 Mini
Specifications:
Specifications:
PM or Call for special forum pricing
2002-2006 Mini
Specifications:
Specifications:
Specifications:
2007-2012 Mini
Specifications:
Specifications:
PelicanParts.com
Aug 4, 2015 02:45 PM
