Running staggered wheels on an 08 MiniS
I'm looking at a set of factory BMW wheels that come 9" wide in the rear and 8" wide in the front. Am I pushing it thinking I can run a 9" wide rim with a small stretch in the rear or is that too wide? I could buy two sets and try to sell a set of just the rears and run fronts but obviously if I can run 9's Id love to. Anyone with advice on the subject feel free to chime in
Plenty of examples of staggered setups on Minis. 8f 9r is pretty standard.
You are thinking of adapters I'm guessing? Unless they are very old BMW wheels. Adapters can be tough on the 2nd generation Minis because of the 14mm lug bolts. No adapter company that I'm aware of has the 14x1.25M hardare that the Mini uses so you will need to use the factory hardware which in turn requires a very thick adapter.
That said: What kind of MINI? R56's have more room than 53's
For heaven's sake this is FWD. The front end has two thirds of the weight and three quarters of the work to do. I run staggered - 8" front and 7" rear.
But to each their own I reckon - whatever makes you grin...
Cheers,
Charlie
Cheers,
Charlie
I had someone tell me he wanted to put a custom 8 pot brake in the front and a 6 pot in the back for a 2600 plus pound car. Also for show.
There are no OEM MINI wheels wider than 7" for the Cooper S using 4x100 bolt pattern and no 9" wide BMW wheels that fit the MINI.
The BMW wheels are off of a e46 M3
Front - 18x8 +49
Rear - 18x9 +23
I'm making adapters, you know, thinking outside the box. This isn't a race car and I'm not trying to turn it into one, also not a show car. It's my car, and inwantnit to be different ten the rest of them. Going to measure it out tomorrow and see what I can come up with, I'm figuring 20mm for adapter
Front - 18x8 +49
Rear - 18x9 +23
Front - 18x8 +49
Rear - 18x9 +23
Front - 18x8 +49
Rear - 18x9 +23
Yea 9" et 0 is way too low. For reference 8" et30 is about dead flush.
Still unless you can source M14x1.25 Hardware with a lower profile then the stock hardware you won't be able to make a thin adapter. I went down this route last year. M14x1.25 is basically a BMW lug bolt specific size, I was not able to find any source for hardware in that size.
With that final rear offset you can and will need fender flares.
Have you done this before? Run wide wheels on a FWD?
Problem is even with a Cooper S, wheel weight of a 18x9 with tire isn't going to be fun to drive. Slower to accelerate, longer to stop, sluggish in handling.
SosoMINI
Nov 22, 2015 03:17 PM
phrza81
Oct 10, 2015 11:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
