R50/53 Where to buy parts online?
I suggest you look through the forum's vendor list: https://www.northamericanmotoring.co..._directory.php
Way Motor Works carries the Clutch Master: http://www.waymotorworks.com/clutch-...tages-1-7.html
Way is good but I have also used PartsGeek and a few other sites vendor sites.
I'm not sure that I would go with a CM clutch. If you are not tracking the car say with stock (Valeo or Luk) kits. The CM clutches have had issues in our cars and you may not be happy with it. I just replaced my clutch with a Luk and it is great. As for what else to replace, you may have to replace the flywheel so be ready for that. If you go with the Valeo kit there is one that way sells for about 500 that has the clutch and a flywheel.
If you decide to go with a CM kit I would get a single mass flywheel and make sure the CM kit has a sprung-hub disc (just give clutch master customer support a call and they'll be able to help you out). Also I would replace the slave cylinder and throwout bearing guide-tube.
blackie
Oct 2, 2015 07:41 PM
