How do I get the clips back on?
Old Sep 8, 2012 | 05:35 PM
scatpack's Avatar
scatpack
What's the secret? The clips that keep the air hoses on... Easy to get off.... Hard to get on!
What's the secret?
Old Sep 8, 2012 | 07:52 PM
kapps's Avatar
kapps
Intake hoses? Grab some pliers (not needle nose) and a small-ish flathead screwdriver. Put the blade of the screwdriver under the clip part and use the pliers to squeeze the clip together. Once it's over, slide the screwdriver out. Use the flat end of the pliers, not the side.
Old Sep 8, 2012 | 08:57 PM
Eric_Rowland's Avatar
Eric_Rowland
Ideally, use a set of ignition pliers - they look like a channel-lock, but are smaller (you can find them at Sears.) Full size work too, but the smaller ones make it easy. Put the top on the 'over' side, and the bottom on the 'under' side. Still takes some practice, but it works.
Old Sep 8, 2012 | 09:28 PM
gerry2153's Avatar
gerry2153
I took the easy way.... I bought some regular ones
Old Sep 8, 2012 | 10:31 PM
Sp4rtan's Avatar
Sp4rtan
The best tool I've found is a set of wire strippers - the kind with the thin flat cutting jaws at the end. Mine are Belden, but there are lots of no-name versions. Totally effortless.
Old Sep 9, 2012 | 05:35 AM
Capt_bj's Avatar
Capt_bj
ditto
or - if we're talking the big hoses for the air intake - there's no pressure to speak of on these lines and a long 'zip tie' works just fine. That's what some CAI kits come with.
surfblue
Oct 24, 2018 01:20 AM
Motown
Apr 20, 2018 09:31 AM
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
absolutcamper
Aug 24, 2015 12:27 PM
