Fuse and/or relay for rear hatch actuator?
Old Sep 7, 2012 | 03:31 AM
joshbagosh's Avatar
joshbagosh
Does anyone know where the fuse or relay is for the hatch actuator that unlocks the hatch? I'm stuck using the pull cord until further notice :-/
Old Sep 7, 2012 | 09:40 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Is the keyfob not working?
888.280.7799 | 6am - 5pm PST
Old Sep 7, 2012 | 11:07 AM
joshbagosh's Avatar
joshbagosh
That is correct, it only unlocks the doors, not the hatch. When I press the button, no power is being delivered to the actuator. I used a light tester and it never lit up. I'm hoping there is a fuse or something for it?
Old Sep 7, 2012 | 11:09 AM
rkw's Avatar
rkw
Fuse F37 (up to 9/2005) or fuse F23 (from 9/2005). There is no separate relay. The actuator is powered directly from the BCM computer. The actuator itself also might have failed.
Old Sep 8, 2012 | 02:12 PM
ERIK06MCS's Avatar
ERIK06MCS
Josh, didn't see this before I posted on your other similar thread.
+1 to rkw. Don't rule out the actuator but if you have no power going to it when handle is depressed and you're sure your microswitch on the handle is functioning properly and also receiving power.
Old Oct 2, 2014 | 08:56 AM
jamfred774's Avatar
jamfred774
Resurrecting an old thread here. I am not getting power to the actuator button on the rear hatch. I pulled the back panel off last night as the wiper motor stopped working and I have the wiper going but the hatch button stopped working and no longer has 12 volts going to it.
It appears that all the fuses are good.
Old Jul 16, 2023 | 09:44 AM
malsalah's Avatar
malsalah
Hello there,
where are theses fuses located?
my mini is 06 cooper S Convertible R52
my hitch actuator stopped work aftering installing a back up camera
trying to see if I burnt a fuse but don't know the fuse # and the location of the actuator of my Mini
Thank you
Wohnson89
Jun 10, 2020 04:53 AM
Toolman
Jan 20, 2016 06:50 AM
nismo4life
Nov 4, 2015 09:18 PM
Red Raven
Aug 11, 2015 04:48 AM
