R50/53 oil on spark plug
Old Sep 2, 2012 | 06:49 PM
I.M. Huge's Avatar
I.M. Huge
oil on spark plug
Excuse me if this is posted here elsewhere-- if it is I cannot find it!
checking/replacing plugs and first plug (left side) had some oil on it. cleaned out tube and wiped off plug, replaced, ran engine for a few minutes and no oil. will check again in morning before replacing plugs. Any ideas what this might be?
thanks
Old Sep 2, 2012 | 06:52 PM
Blackbomber's Avatar
Blackbomber
O ring in valve cover, I would say.
Old Sep 3, 2012 | 05:56 AM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
#5 in this diagram is causing your problem. I need to do mine as I have 2 that are not sealing properly. Yesterday I changed my plugs and found oil on 2 plugs. If you stick a piece of paper towel or something in between the valve cover and plug tube top where the gap is, you will most likely find a pool of oil as I did.
http://realoem.com/bmw/showparts.do?...87&hg=11&fg=15
Old Sep 3, 2012 | 03:18 PM
I.M. Huge's Avatar
I.M. Huge
thanks guys for the comments and suggestions. Will check the o-rings and will let you know.
maniacalmorgan
Jan 1, 2020 11:20 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
HaveATank
Aug 24, 2015 10:26 AM
yashmack
Aug 15, 2015 10:16 AM
