Oily residue on back window, head gasket?
Old Aug 30, 2012 | 03:40 PM
dwebber18's Avatar
dwebber18
Hey everyone I just found a coolant leak in my R56 and replaced a broken water pipe and thermostat housing. Now when I drive it I'm getting an oily residue on the rear window and hatch. I'm thinking maybe the leak caused some overheating and blew the gasket or something else. I did check and there is no fluid in the spark plug holes if that matters. It only gave me the overheating warning once and I drove it for another 2 minutes before it was parked and new coolant was added while. It was about a week before the problem was discovered but I kept an eye on the coolant and it never gave me the overheating warning again. What do you all think it could be? Thanks
Old Aug 30, 2012 | 04:16 PM
pheatton's Avatar
pheatton
Whats the oil lever look like and does it look funny, milky?
Old Aug 30, 2012 | 04:18 PM
dwebber18's Avatar
dwebber18
It looked alright a week ago but I'll check it out tonight and post back here.
Old Aug 30, 2012 | 06:54 PM
dwebber18's Avatar
dwebber18
Oil looks good, not milky or anything.
Old Aug 30, 2012 | 07:16 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Seen a MINI blow a oil filter cap O-ring once. They had been driving down the highway when it happend. The boot and glass was covered with oil carried there from the air flow and vortex of air at the back of the car.
Maybe you still have a leak when system is under pressure.
Old Aug 30, 2012 | 07:18 PM
dwebber18's Avatar
dwebber18
That's what I'm thinking or it could just be from all the coolant that spilled working its way out of all the cracks and stuff where it landed.
Old Sep 2, 2012 | 12:14 PM
krim's Avatar
krim
Happened to me, leaving dealer after an oil change. The tech didn't get the new o-ring on correctly and it blew once i got on the 210. Didn't notice til i was almost home. Fortunately, there was still over 1/2 of the oil left when I called roadside service for a tow back.
Check your driver side wheel well, if there's oil soaked into the liner, that could be what happened.
Old Sep 6, 2012 | 06:41 AM
dwebber18's Avatar
dwebber18
Looks like the oily residue was due to a small coolant leak that I still had from the plug in sensor on the thermostat housing. Got that all fixed up but now it doesn't seem like the turbo is making boost and it feels sluggish. Now that has me worried.
surfblue
Oct 24, 2018 01:20 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
atenzany62
Aug 9, 2015 05:54 PM
MIminiclubman
Aug 5, 2015 09:14 PM
kwijmbo
Aug 5, 2015 09:00 PM
