Electrical Need help with xenon retrofit
So I have the factory housings, bulbs and ballasts, im trying to do the retrofit coding.
as far as I understand, the VO in the CAS module needs to have $522 added. I did that with NCS expert,
but the part im not sure about is what happens next with the FRM? Do I need to reset it? How do I do this? do i write a blank .man file to the module?
once done, what should I expect? I have yet to do the retrofit wiring, from what I understand, the low beams are supposed to work, correct?
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
