R58 Water temperature high?
Old Aug 1, 2012 | 05:51 AM
user 837978240's Avatar
user 837978240
My wife's JCW Coupe has the sport gauges installed. One of the gauges measures water temperature in Celsius. When warm, the temp consistently reads around 100 Celsius (212 Fahrenheit).
Is this normal?
Old Aug 1, 2012 | 06:24 AM
BlueToy's Avatar
BlueToy
Is this normal?
I have the same factory temp. gauge. Mine runs right around 105C/222F.
-Steven
Old Aug 1, 2012 | 07:00 AM
Braminator's Avatar
Braminator
Yes it is in the normal range.
Old Aug 1, 2012 | 07:35 AM
BillTheCat's Avatar
BillTheCat
I use an OBDII transmitter with an Android app called Torque, and have also used a Dashhawk for OBDII display. Both consistently show coolant temps between 98-105C, depending on operating conditions.
Most German-engineered cars used a closed, pressurized system, which is why it is OK for them to reach the boiling point. The fluid isn't going anywhere, unlike a standard cooling system as found on most American or Japanese cars, where the radiator cap is designed to open up & relieve the pressure by venting coolant. (And where there is a non-pressurized reservoir to allow coolant in & out of the system to keep the pressure down)
***This is also why it is 10 times more important to never open the coolant reservoir on a German engineered car when the engine is hot- that sh*t is hotter and under WAY more pressure than you think. That's a mistake almost nobody makes twice, unless they're a little daft.
TREX
Nov 2, 2019 07:31 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
tylewis
Aug 18, 2015 06:53 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
