H4/H7/H11/9005 HID Xenon Lights Sale at Tmart.com- Always Worldwide Free Shipping!
Old Jul 28, 2012 | 01:09 AM
Tmartauto's Avatar
Tmartauto
Hi, all NAM members. Today Tmart recommend several HID Xenon Light Bulbs/Kits for Mini Cooper (S) & Mini Countryman drivers.
You can choose the bulbs that is compatible with your car by yourself from http://www.tmart.com/Car-Lights/.
If you know which item on Tmart is also compatible with Minis, you can also share with us here.
Here we go. First for Mini Cooper or Mini Cooper S, you can choose H7 as the low beam, 9005 as the high beam, and H11 as the fog light.
It's easy to install the HID Xenon Bulb, you only need attach HID bulb to the original lamb hole, stick ballast and connect the power.
35W H7 8000K HID Xenon Car Lights Bulbs (Pair)
http://www.tmart.com/35W-H7-8000K-HID-Xenon-Car-Lights-Bulbs-Pair_p117811.html
H7 8000K 55W HID Xenon Car Lights Bulbs (Pair)
http://www.tmart.com/H7-8000K-55W-HID-Xenon-Car-Lights-Bulbs-Pair_p116147.html
Besides the HID bulb, the HID Xenon Conversion Kit is also a great choice if you want brighter, safer, longer life span & lower power Consumption.
35W H7 3200K Prime-X Car HID Xenon Light Conversion Kit
http://www.tmart.com/35W-H7-3200K-PrimeX-Car-HID-Xenon-Light-Conversion-Kit_p111612.html
9005 8000K 35W HID Xenon Car Lights Bulbs Conversion Kit
http://www.tmart.com/9005-8000K-35W-HID-Xenon-Car-Lights-Bulbs-Conversion-Kit_p139014.html
H11 55W 3000K HID Xenon Car Lights Bulbs (Pair)
http://www.tmart.com/H11-55W-3000K-HID-Xenon-Car-Lights-Bulbs-Pair_p123557.html
35W H11 3000K HID Xenon Car Lights Bulbs (Pair)
http://www.tmart.com/35W-3000K-HID-Xenon-Car-Lights-Bulbs-Pair_p117810.html
http://cdn2.image-tmart.com/prodimgs/Q/Q01356/35W-3000K-HID-Xenon-Car-Lights-Bulbs-Pair_320x320.jpg
For Mini Countryman, you can choose H4 as the headlight, because it's low light & high light integrated as one. And you can also choose H11 as the fog light.
H4L 6000K 35W HID Xenon Car Light Bulbs (Pair)
http://www.tmart.com/H4L-6000K-35W-HID-Xenon-Car-Light-Bulbs-Pair_p140456.html
Other Accessories
H1/H3/H7/9005/9006/9007/H4 HID Xenon Lamp Power Line
H3/H8/H9/H10/H11/880/881/H13 HID Xenon Lamp Connecting Line
9005/9006 HID Xenon Lamp Connecting Line
55W HID Xenon Thick Ballast Car Conversion Kit (General Type)
H11 35W 6000K HID Xenon Thick Ballast Conversion Kit
Note:
1. The promotional items are all in stock in our US warehouse.
2. All the items are worldwide free shipping on Tmart.com.
Old Jul 28, 2012 | 01:15 AM
Tmartauto's Avatar
Tmartauto
Tips on how to install HID Xenon lamp
The installation steps of HID Xenon lamp:
1. First, open your car hood and turn off the power
2. Check whether the model of headlights correspond with your car
3. Remove the original vehicle lamps and circuit wiring
4. Drill a hole (About 25 mm diameter) in the middle of the rear cover of the headlamp with a hole saw used for the leading-in of Xenon lamp wire
5. Take apart the safety tube of xenon lamp
6. Put the xenon bulb into the headlamp unit and lead out high voltage wires from the hole, and cover the hole with rubber ring in order to prevent water and dust into the headlamps
7. Fixed the ballast in the right place with screws or mounting bracket, and the best installation location is away from the car engine, such as the side or below of Headlamps and bumper
8. Connect the high-voltage line of ballast with the xenon bulb
9. Connected to 12V power wire and control line, the red one is positive and the black is negative
Old Jul 28, 2012 | 01:17 AM
Tmartauto's Avatar
Tmartauto
Handling Precautions on installation of HID Xenon lights
Handling Precautions on installation of HID Xenon lights:
1. In order to secure installation, please wait for cars and engine cool completely
2. Please make sure the gear is in neutral before installation
3. Please make sure the switch is closed when installing
4. Be careful not to get burnt when switch the car lamp
5. Be careful not to beat and scratch the bulb
6. Don't touch the bulb with your fingers, because it will leave stain on bulb
7. Please check connector, Interface port and the wire connection, because the wrong connections will cause lighting problems
8. Please don't let the bulb terminal access to the internal lens hood of headlight assembly
9. Please drill a hole (25 mm) in the resin or rubber back cover of the headlamp
10. Please make sure the polarity is correct for the connection between bulb and High-voltage starter
11. Please make sure the polarity is correct for the connection between ballast and power source
Old Aug 2, 2012 | 07:14 PM
Tmartauto's Avatar
Tmartauto
$13.69 H7 55W 8000K HID Xenon Car Light Bulbs (Pair)-12003422
Old Aug 2, 2012 | 07:34 PM
Tmartauto's Avatar
Tmartauto
$8.69 9005 35W 8000K HID Xenon Car Light Bulbs (Pair)
phrza81
Oct 10, 2015 11:37 PM
Lee-Oh_825
Aug 11, 2015 10:27 PM
PatrikKN
Aug 5, 2015 09:10 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
