Traklite 1.0 17x7 on R56
I picked up some Motegi Traklite 1.0 17x7 wheels from a local guy. they are 4x100 bolt pattern. I need to find out from someone that is running these wheels on what size hub rings they are running. I havent been able to find much about the Traklites. I think they might be 71.5mm (outside diameter) and I think the mini bore is 56.1mm.
Can anyone confirm this?
Motegi has no info posted on their site about the Traklites.
There are more than one version of the Traklite wheels
see
http://www.j-body.org/forums/read.ph...=47745&t=47713
5 or 6 spoke
likely centerring needed
70.1mm to 56.1mm for MINI hubbore. You can measure your wheels and see if that is correct. Or you can take the wheels to a wheel shop and they can measure for you.
Then you can purchase rings in hard plastic or metal to fit.
http://www.justforwheels.com/hub-centric-rings.jsp
This site has a set of four rings for about $36
This site has alloy rings for $35 a set and plastic for $25 a set of four
http://www.motorsport-tech.com/4DCGI...gs_choose.html
see
5 or 6 spoke
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 4, 2015 01:32 PM
