symptoms of a failing slave cylinder??
Old Jul 20, 2012 | 12:52 PM
Clint Johnson's Avatar
Clint Johnson
Is my slave cylinder failing?
My 06 MCS was running/shifting great, got to work and parked no prob. I got in it to goto lunch and noticed it took a bit of effort to get into reverse but thought nothing of it. Then while driving, the clutch started feeling weird (almost spongy), It feels a bit light until its almost all the way to the floor and its getting increasingly difficult to shift. Any Ideas? I should also note that my clutch has never slipped, not one time. I also checked for leaks around the master cylinder and verified that the fluid is full..
Old Oct 16, 2012 | 06:38 PM
djisback's Avatar
djisback
did you check to see if your leaking fluid from your slave clutch cylinder?
Old Oct 17, 2012 | 10:57 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
A spongy clutch pedal or long pedal travel sounds like symptoms of the slave cylinder going out, read here for more information: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
drrigg
May 27, 2022 03:31 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
SneedSpeed
Oct 1, 2015 03:01 AM
Mikal68
Sep 25, 2015 04:09 PM
