R60 Removing Amber and Red fender reflectors?
Any member have instruction on how to take off the front Amber reflectors and rear red reflectors? Just pick up my CMS ALL4 yesterday and want to spray tint them black.
Thanks in advance
Thanks in advance
You might want to check out this thread as it could give you some answers:
https://www.northamericanmotoring.co...white-one.html
Good luck and enjoy your Countryman!
i tried several thing before getting it right. first i tried a overlay from bimmian.com. that SUCKED. waste of money. then i tried spray tinting on the car. ok but could not get around the edges, so it looked bad. i ended up removing them and spray tinting again. they look awesome now! i used plastic pick tools to loosen the plastic rivets (plastic spoons or butter knifes would do the job). just back and forth on each side of the rivets loosens them. if i remember correctly you only need to remove 2. there is one nut that screws onto a plastic nub on the back of the reflectors. thats it. a tip is to put a dab of superglue, "or somthing" on the rivet when re-installing. it will not hold in as tight as it originally did, but not necessary. i noticed mine backing out a little. but do not fall out or anything.
i hope this helps
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
Apr 20, 2018 09:31 AM
minipopkart
Aug 13, 2015 05:22 AM
bctf1
Aug 6, 2015 12:55 PM
