R50/53 need some advice for tuning MC
Old Mar 15, 2004 | 10:51 PM
isykal's Avatar
isykal
hi! i have a MC and i want to increase the horsepower to about 140-150. can anyone give me some advice? thanks
p.s. i have a CVT
Old Mar 15, 2004 | 10:56 PM
hondacivic's Avatar
hondacivic
>>p.s. i have a CVT
Turbo.. That gets you up to 200hp on stock internels. Peter at m7 tuning built it and it kicks ***.
Old Mar 15, 2004 | 11:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Certainly turbo is an option as is nitrous. talk to M7 if you are interested.
For a normally aspirated MC it would be harder to get to 150 HP. Read on.
Search for past threads. See
https://www.northamericanmotoring.co...amp;topic=6047
CVT with Many Mods. See
https://www.northamericanmotoring.co...mp;topic=20462
and
https://www.northamericanmotoring.co...mp;topic=21105
Old Mar 16, 2004 | 01:13 PM
isykal's Avatar
isykal
thankyou so much! u guys are great!
Old Mar 16, 2004 | 02:03 PM
jazmini's Avatar
jazmini
Hey isykal,
I want the same thing you do, but need to wait til I pay off my MINI. If you're in California, you may want to consider the M7 turbo (forced air induction) as I think it will be Carb legal there. Whereas if you keep your motor naturally aspirated and upgrade that, probably most or many of the upgrades may not be Carb legal in Calif. The M7 turbo (currently under development, but about to be finalized) has a mild boost (i.e., maybe 6 psi or more if I remember right), so (hopefully) will not be too stressful on your engine. It may generate over 150 hp. A high boost gives more power but generates more heat and stress. Your CVT transmission was not designed for that or the engine internals, but appears to be able to handle some increase in hp and torque.
Also, M7 is currently developing light weight parts for the MINI, and that will be a big performance increase. That would also help braking, handling, gas mileage, etc. So, you may want to keep up with his developments and check them out as they come out. For example, if you have had a car before with a small engine, you will know the difference when you are driving by your self or with another passenger or two. Big difference. So, even if you could only knock off 100 lbs, that would be a big improvement. However, it may be possible to knock off 200 lbs or even 300 lbs. The sky may be the limit.
Good luck and keep us informed as to what you do.
Old Mar 16, 2004 | 10:54 PM
rfibanez's Avatar
rfibanez
As others said Peter is the guy to talk to if you want your MC or MCS to really perform! :smile:
Here are a few useful links to some of M7's products :smile:
kevinlhr310
Aug 27, 2015 06:45 PM
Aug 27, 2015 12:25 PM
Aug 12, 2015 01:24 PM
M7Speed
Vendor Group Buys
Aug 10, 2015 12:32 PM
