FS:: KONI FSD shocks R56 R57. R58 $450 delivered or $400 Pickup in IN
Old Jun 5, 2012 | 01:15 PM
KLOIN's Avatar
KLOIN
Smile KONI FSD shocks R56 R57. R58 $450 delivered or $400 Pickup in IN
Category: Suspension
Price: $400
Part fits (you may select multiples): R56, R57, R58
Location (Region): Midwestern
Closed due to me installing them on new Countryman.
Selling my set of KONI FSD shocks as I have upgraded to a SPort shock after using these on the street for 10K miles. These are cvery clean and have a lifetime warranty. Paid $699 but am letting them go for $400 or $450 delivered in the US...
The KONI FSD (Frequency Selective Damping) shock for the Gen2 MINI Cooper combines excellent road holding and handing characteristics with no-compromise comfort levels. Firmness for sporty driving on even road surfaces. Smoothness for a comfortable ride on uneven road surfaces.
It's possible via KONI's patented Frequency Selective Damping technology - technology that actively controls the damping level on the basis of the vehicle's body and suspension movement frequency. FSD shocks are a smart suspension system that adjusts automatically and in a fraction of a second to road conditions and driving style. FSD shocks for the MINI Cooper should be used with your factory springs, if you're looking to lower your MINI checkout our KONI Sport Shocks. Price includes (2) front and (2) rear. Picture is for reference only.
How It Works:
In standard shock absorbers the main damping characteristic is defined by the oil flow going through the piston assembly (1). Combining it with the FSD feature (2), KONI added a special valve that controls an oil flow parallel to the one going through the piston rod (3). This parallel oil flow is closed by the FSD feature, giving a rise in damping force almost linear to the time that the piston is moving in one direction
Put Simply:
The FSD feature is a hydraulic amplifier that delays the build up of pressure. In some ways an extra tuning option has been created in order to get the best possible combination of handling and comfort. Since it is an integrated part of the hydraulic valve system inside the damper, no additional cables, sensors or any other electronic devices are needed to operate an FSD damper.
Benefits:
Excellent road holding and handing
Improved grip
Great stability
Optimum comfort level
Excellent body control
Added comfort for low profile tire applications
Maximized driving pleasure
No electronics, sensors or other components needed
Economical, effective solution
LIFETIME Warranty
Kit Includes: KONI FSD Part # 2100-4099
(2) Front FSD Shocks
(2) Rear FSD Shocks
Fits the following MINI models:
R55 2008-up Clubman and Clubman S
R56 2007-up Hatchback Cooper and Cooper S
R57 2009-up Convertible Cooper and Cooper S
Attached Thumbnails KONI FSD shocks R56 R57. R58 0 delivered or 0 Pickup in IN-koni-fsd-frequency-selective-shocks-060512.jpg
Last edited by KLOIN; Jun 16, 2012 at 09:12 PM. Reason: Decided to install on new Countrynm
Old Nov 22, 2012 | 05:47 PM
Daddyo's Avatar
Daddyo
pm sent
cerenkov
Apr 24, 2018 07:47 AM
jaydeeps
Dec 8, 2015 09:13 PM
Aug 19, 2015 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 9, 2015 09:42 AM
