Here's one for you Alex..18x7.5x45mm with....
new 205/40-18 Michelin Pilot Sport 2's due in June. Is the 45mm offset going to get me in trouble with the strut housing? I am close now with my stock 17x7x48mm with a 215/45-17 pzero. I appreciate you opinion, thanks!
P.S. Section width is 8.4" on a 7.5" rim and 24.4" Diameter.
These new michelins are the bomb and have suprisingly supple sidewalls (are supposed to be a quieter smoother riding tire (not to mention F1 sticky) than the pilot sports.
I am running a 225/35/18 on SSR comps with no problems, section width is 9.1"
, dia. is 24.3", also the rim is 18x7.5, +42mm offset....There is room left on mine if you want i will measure, i also have coilovers and still doesnt rub, i did have stock and also had no rubbing problems.. Hope this helps you some....
The new 18" JCW wheels will be fitted with 205/40-18 Dunlop SP Sport 01 DDST tires. This wheel is only 7" wide but has a 52mm offset and requires a "steering stop" retrofit kit.
I think you should be OK with a 45mm offset.
I have yet to recieve any tires in 205/40- So i have yet to add them to my fitment database. Sounds like it may be an issue, due to lower offset than JCW, but that lower offset may adequatly space it back out. Once I get tires we'll check it out.
Alex
Alex
Mike_Mini2
Apr 29, 2026 06:02 PM
Navigation & Audio Help needed with suggestions for Audio upgrade.
DreamingTwig
12
Jul 1, 2010 10:52 AM
Navigation & Audio Basic sound system question...
Mr_Bueno
Apr 11, 2009 01:42 PM
