Suspension Clicking Sound - HSport Control Arm?
Old May 17, 2012 | 05:13 PM
namsayin's Avatar
namsayin
2012 MCS with about 7k miles. At around 1k miles I put on NM Engineering Springs (stock shocks) and HSport control arms. Had them installed by a certified BMW tech (guy started his own shop after working at BMW for 20 years) back home when visiting for the holidays. Had them do the alignment at the same time.
6k miles have past and not one problem. Took my car into the dealership (Mini SF) last thursday for an oil change. Ever since I picked it up, it makes this loud clicking sound when starting and stopping. Sounds like a suspensions noise from the Rear Drivers side.
Took it to the dealership today and they looked at it. They said the springs are perched properly, sway bar bushings are fine. The only thing they could suggest is that maybe the HSport control arm i installed was not lubricated properly and having issues? They then said it wasn't their part so I would need to take it to a specialty shop to have them look at it (I figured they would say that).
Question is - Anyone ever experience a similar issue? Is there special greasing that needs to happen to the HSport control arm?
Thanks in advance!
Old May 18, 2012 | 09:38 AM
countryboyshane's Avatar
countryboyshane
There is a grease fitting on each end of the h-sport rear control arm. They need to be lubricated with a lithium grease from time to time. I would suspect a squeaking noise not a click though. Either way, the old grease can get washed out and you need to re-grease when that happens.
Old May 18, 2012 | 02:12 PM
namsayin's Avatar
namsayin
Thanks Shane. Since I didn't install them this question hopefully isn't stupid - Can I grease them from under the car or do I need to unbolt them to fully grease them?
W0TM8
Dec 19, 2019 07:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
