R56 cleaning oil filter cover during oil change
Old May 5, 2012 | 11:07 AM
urameatball's Avatar
urameatball
Anyone ever done this?
When I did my last oil change, I tried rinsing the filter cover and was astounded by how much dirt I had removed. I figure I'd just rinse it with some handsoap in my sink and moments later, my sink was COVERED in a THICK black film of dirt and particles.
I didn't want to clog my sink so I didn't try doing a thorough cleaning of the cover. I can only imagine there still being a LOT more dirt that I haven't removed from the cover.
thoughts?
Old May 6, 2012 | 05:46 AM
richardsperry's Avatar
richardsperry
I've got a parts washer in my garage, along with a lift, so that isn't a problem for me. You can buy a workbench sized parts washer... Or use a disposable aluminium pan, and buy some Blue Lighting parts cleaner, or Castrol Purple cleaner, or use Simple green.......
Old May 6, 2012 | 03:59 PM
DogT's Avatar
DogT
I always clean the cover when it's off. It's not hard to spray some carb cleaner in there while you're cleaning everything else up.
Old May 6, 2012 | 04:58 PM
MINIdave's Avatar
MINIdave
Absolutely.....I also have a parts cleaner setup, but like the others said, no reason you can't use some carb spray or simple green or even hand cleaner.
Old May 7, 2012 | 02:42 PM
urameatball
Good to know, I would have hesitated to use something as strong as carb cleaner, but if you can do it, so can I
Old May 20, 2012 | 05:52 PM
jlee924's Avatar
jlee924
Brake parts cleaner works fairly well to clean the filter cap.
Kimolaoha
Jul 5, 2023 01:04 PM
polotska
Aug 23, 2015 09:10 AM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
M7Speed
Aug 6, 2015 01:48 PM
