Red spots eeek!!
Old Apr 21, 2012 | 07:46 PM
micromini234's Avatar
micromini234
Red spots eeek!!
So I was under my car tonight and i noticed this red spots of liquid, I figured it was just some the spilt over from when the cvt fluid was changed, but looking deeper I found some on the ac line low side next to it, some on the transmission housing and some in various spots on the 2 black lines that run parallel down the car on the driver side I'm really confused is this a bad transmission seal or leak?
Old Apr 23, 2012 | 05:35 AM
OVREZY's Avatar
OVREZY
I just had my cvt oil cooler and oil cooler lines replaced because of a leak, you might check those out.
Old Apr 23, 2012 | 06:21 AM
micromini234
Ok Where would those be near
Old Apr 23, 2012 | 04:49 PM
micromini234
Ok I just went under and found this... Err is this one of those plugs used to fill, drain or inspect the level of the fluid? or is this just something different leaking? I called mini and they said if it is one of those thigns they would make it right.
devicemanager
Jun 17, 2016 06:18 PM
dirtyscarab
Aug 23, 2015 07:50 PM
Aug 19, 2015 12:51 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
Aug 12, 2015 01:24 PM
