R50/53 67k Miles, Maintenance?
Old Apr 17, 2012 | 11:36 PM
Minicoopr50's Avatar
Minicoopr50
My 06 r50 is almost at 70k miles. What maintenance should i be doing?
When i got her she was at 55k, so i dont know exactly what had been done already.
Old Apr 18, 2012 | 03:45 AM
GoThingNC's Avatar
GoThingNC
If you do not know the history I would at least:
Change oil/filter
Change Brake Fluid
Change Gearbox Fluid
Change Drivebelt
Change Air Filter & Pollen Filter
Change Power Steering fluid and check PS fan operation
Check radiator fan - low and high speed
Change coolant
Top off blinker fluid
Replace tires if over 5 years old
Inspect strut mounts, lower control arm bushing (probably worn) , brake pad thickness.
Good luck
Old Apr 18, 2012 | 07:18 AM
G0LDENDOMER's Avatar
G0LDENDOMER
+1 on the blinker fluid. i ran dry one time, man was that a headache!
Old Apr 18, 2012 | 01:54 PM
GoThingNC's Avatar
GoThingNC
Blinker fluid is now $18.95
No wonder why I don't see anyone using their directionals any more
http://kalecoauto.com/index.php?main...products_id=22
Might want to add Summer air to the tires while you are at it
http://kalecoauto.com/index.php?main...products_id=31
Old Apr 18, 2012 | 02:07 PM
sbeezy's Avatar
sbeezy
^bahahahahah!!!
Old Apr 18, 2012 | 02:56 PM
ZippyNH's Avatar
ZippyNH
Inspection #2 was due at ABOUT 60,000 miles....so it was likely not done...
check on the site here or the manual for the items. It is mostly labour, plus a few filters and fluids.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
jrezzo
Aug 9, 2015 10:32 PM
kwijmbo
Aug 5, 2015 09:00 PM
