Lightweight wheels for MINI
Old Apr 17, 2012 | 08:57 AM
Mach V Dan's Avatar
Mach V Dan
Introducing the all new RSe12 light weight wheels. Inspired by NM Eng's RSe14 for the Countrymen, the RSe12s feature fewer spokes to optimize the weight saving and visually 'open up' the design. The RSe12 were designed specifically for the MINI Coopers, which translates to complete direct bolt-on fitment utilizing factory lug bolts, center caps, tire pressure monitoring sensors, as well as the Run-Flat tire – No spacers, No hub rings!!
At just 18.8 lbs, the RSe12 is one of the lightest 18" wheels we have ever sold. They will enhance performance by reducing the rotational mass and unsprung weight.
Specifications:
  • Size: 18x7.5
  • Offset: +45 mm
  • PCD: 4-100mm
  • Bore: 56.1mm
  • Lug Opening: 14mm Conical Seat
  • RSe12 is OEM TPMS (Tire Pressure Monitoring System) compatible.
RSe12 utilizes OEM Mini or JCW center caps and lug bolts, which are not included with the wheel.
NM Engineering RSe12 -- click me!
Click the link for pricing and ordering.
--Dan
Mach V
andrewjg1994
Jan 29, 2021 07:45 PM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Dashdog
Aug 10, 2015 06:17 AM
