Wheel Size Change Recalibration Requirement
Old Mar 6, 2004 | 12:34 PM
SCMCS's Avatar
SCMCS
Does changing the wheel size require any computer/speedo recalibration?
Say going from a 16” to a 17” wheel change? Of from a 16” to 18” wheel?
Old Mar 6, 2004 | 12:49 PM
kenchan's Avatar
kenchan
Since you want to keep the outer circumference of the tire the same size,
you don't need to get your ECU or speedo, etc. re-caliberated. :smile:
The wheel diameter might be larger, but the tire sidewall has less
profile, so the circumference stays basically the same.
a few examples:
Tirewidth (mm) / profile (% of tirewidth) <-sidewall width
195/55 tire size for 16"
205/50 tire size for 16"
205/45 tire size for 17"
215/40 tire size for 17"
and so on.
:smile:
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, Anthrasite Int, TK5 16x7, 6CDMP3, etc.
Old Mar 7, 2004 | 06:38 AM
SCMCS's Avatar
SCMCS
Ah yes this makes perfect sense. Thanks for the info.
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
wind715
Aug 11, 2015 07:56 AM
