R56 left front parking light
Old Apr 14, 2012 | 03:53 PM
bigbacon's Avatar
bigbacon
Where can I get one for an 08 cooper without fogs?
Lens on our got wacked by a rock and broke. I assume its easy to replace? remove that cover in the wheel well and unscrew some stuff?
guessing part number #63 17 2 751 293
are they the same on either side?
Old Apr 14, 2012 | 05:09 PM
bluefox280's Avatar
bluefox280
Yep, that's the correct part number for a parking light only (no fog) assembly: #63172751293
They are not side specific; they'll work on either side of the vehicle.
- Erik
Old Apr 15, 2012 | 09:13 AM
bigbacon's Avatar
bigbacon
Is it easy to replace? Are there instructions somewhere
Old Apr 16, 2012 | 12:51 PM
ammodave's Avatar
ammodave
Penske wants about $55; if you do a little shopping (eBay, used parts, etc.) you should be able to find it for about $25-$30. Unfortunately, the left side is much harder to replace; the windshield washer reservoir is in the way when you try to remove it from the backside. Most folks here on NAM end up removing the front bumper. When I replaced my parking lights with oem fogs last year, I chose (what I think) was an easier way. First, remove the left headlight (4 bolts + 1 electrical connector). This will give you access to the parking light from above. Then remove the bulb from the light housing. Next, unbolt the light (an offset torx screwdriver will be handy). Then remove the light from the mounting bracket. The next part gets a little tricky and involves lying on your back under the car. Remove several of the fasteners holding the fender liner in place so you can access the bottom of the reservoir. Unfasten the reservoir (1 or 2 bolts + a plastic fastener up top). Now you should be able to push up on the reservoir far enough to remove the light thru the bottom. Reassemble everything and you're done. It took me about an hour. Good luck.
Old Apr 17, 2012 | 04:31 AM
bigbacon's Avatar
bigbacon
eww.....I guess I'll see if it is covered under the extended warranty we have and not deal with it. only a $100 buck if so vs 50 for a new one and my free labor.
Wohnson89
Jun 10, 2020 04:53 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Zettinger
Aug 25, 2015 04:04 PM
FLYM1N1
Aug 15, 2015 11:20 AM
