Is oil in the intake tube and supercharger normal?
Old Apr 11, 2012 | 07:46 PM
PLast's Avatar
PLast
I have a 2006 MCS with only 22,000 miles. I noticed oil on the front of the engine which is coming from the crank position sensor o-ring. The check engine light has come on and is throwing the 2096 code (lean). I decided to pull the front of the car off to replace the sensor o-ring and to replace the green supercharger intake gasket to try to solve both problems. When I pulled the intake tube off, the green gasket was saturated with oil and there was a small amount of oil in the intake tube and SC.
My question, is oil in the intake normal or is this coming from the rear compartment of the SC?
I didn't really want to pull the SC off at 22,000 miles but maybe I should change the SC oil while the front end is off.
Attached Thumbnails Is oil in the intake tube and supercharger normal?-img_0356.jpg   Is oil in the intake tube and supercharger normal?-img_0361.jpg   Is oil in the intake tube and supercharger normal?-img_0358.jpg
Old Apr 11, 2012 | 07:59 PM
SPDinNY's Avatar
SPDinNY
I think it is normal, mine had some in it. Usually people run engine degreaser through the intercooler then rinse it and dry it out good. (blow out with air hose)
Old Apr 12, 2012 | 09:30 AM
proximo's Avatar
proximo
Yes, the oil is normal. It's caused by piston blow-by and is inherent in any car. While not threatening (with preventative maintenance) it will eventually build up a residue inside the engine and degrade performance. You can add a catch can to the system to reduce the oil through the intake system. I have one on my Challenger and it removes 2 oz of oil every couple of months (maxed at 4 oz in 6k miles to date). Some other owners have removed half a can (guesstimate a quarter of a quart) in a month. As soon as I can find the right one I like, I'll have one on my wife's MCS, just haven't taken time to find the one I like.
Old Apr 12, 2012 | 10:03 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Make a catch can with a short length of black PVC, two end caps, a couple of threaded barb fittings and a radiator petcock. Drill two holes for the barbed fittings in one end cap and one hole in the other for the petcock. Once you've cemented the fittings in place, then cement the end caps to the short length of PVC. You can use a stainless steel band clamp to hold it in place with the petcock on the bottom, then attach your oil-proof hoses to the appropriate lines. Every few months, I use a discarded spray can top to drain any collected oil out. "Don't need no stinkin' sight glass!"
Attached Thumbnails Is oil in the intake tube and supercharger normal?-dscn2395.jpg
Old Apr 12, 2012 | 06:19 PM
PLast's Avatar
PLast
Thanks for your responses. Glad to hear that the oil is normal. I think the catch can is a great idea. Will definitely get one after seeing the amount of oil accumulating in the intake tube.
Old May 30, 2012 | 04:49 AM
ACallahan's Avatar
ACallahan
Good catch cans have baffles inside to help keep the crud in.
09R56
Nov 16, 2022 10:49 AM
wkp1219
Nov 13, 2015 07:52 AM
Mib4840
Oct 13, 2015 10:10 AM
The_Kid
Aug 28, 2015 04:50 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
